bilz
Newly Retired!😁
- Mar 15, 2011
- 2,228
- 3,163
1200 sq ft home with detached garage. Need re roof, sand blast, stucco, wood work painted and the whole thing tented. Best to go separate or find a contractor?
It really depends on your budget and availability to manage. As a GC I basically coordinate subs and push the schedule at a typical 20-30% mark up on my subs. If you can manage and find guys that can keep your schedule go for it.1200 sq ft home with detached garage. Need re roof, sand blast, stucco, wood work painted and the whole thing tented. Best to go separate or find a contractor?
Just a thought, we do heat treatments for termites. Nothing goes on the roof so no risk to breaking tiles. And we're done in one day and you can come back the same day.Sand blast stucco after tenting but before roofing? I haave had them all done before but have never needed them all at the same time.
Good candidate for mini-split units sounds like.List just grew. Would like to add hvac, There is none. House had central heat, but it never worked well, the unit is gone. The attic is very shallow, not sure there is any room for equipment. Also would need panel upgrade.
What's the process for this sounds better than filling my house full of chemicalsJust a thought, we do heat treatments for termites. Nothing goes on the roof so no risk to breaking tiles. And we're done in one day and you can come back the same day.
Same warranty as fumigation.
@hallett21 has done the last few panels for me.Mini splits would be fine with me and the wife. Guess I need to get an ac guy out. For sure I need a new panel.
I heard heat was used for bedbugs. How do you handle bedbugs?Do the fumigation first don't do heat treatment ever it doesn't work period. Do the roof afternoon sand blast. Mew lumber should not have termites in it this time of year in a couple of months it could but not now. Paint once wall work is done it keeps everything clean and fresh just mt option
Basically we seal house off from the outside with plastic sheets to lock heat and heat the house up to a specific temperature for a specific time to kill the termites and there eggs. There is some prep work involved on your side and certain homes are not good candidates because of the high temp.What's the process for this sounds better than filling my house full of chemicals
Fumigation is great for bed bugs as well as termites the just use 3 times as much gas and hold that level for a longer period of tim. How ever if it a multi family building then you must use heat it's a lot more work could take multiple days to complete all clothing would need to be heated to high tempsI heard heat was used for bedbugs. How do you handle bedbugs?
