73hondo
- Dec 20, 2007
- 302
- 111
any howard guys... what kinda speed and HP to they like?? not sure if all the bottoms are the same but looking at late 80's models.
man thats a beautiful boat, so depending on set up 1000 ponies should get you to the century mark... does it handle fairly well at those speeds... I have own some fast flats just wodering if they are a hand full??
My 1983 Howard has been as fast as 110 on radar. Thats the very best with good cool air, just me in the boat and about 20gals. of gas and with a 2 blade. It does have a full interior though. As mentioned I have changed the strut angle to 7.5 degrees and moved it forward 7" and worked on the bottom. The engine is a 548 ci with Canfield heads and a 10:71 blower with Super Chiller and 12 lbs of boost. I run 48 % gears in the Casale and the prop is a 2 blade 11 3/4 X 16 Menkens. Engine turns about 6300 rpm's Those speeds were reached with pump gas and a flat tappet cam. I have since changed to a roller cam, but don't think it is any faster,maybe quicker. I also have the 1 7/8 id lightning headers. The engine is not a professionally built engine. I put it together myself and it was together for 8/9 years before I freshened it up last year.
Oh, with the changes I have made it handles very well. I wouldn't want to run it through any nasty water at that speed though. It carries the nose sorta like a flat bottom, with the turn fin about half in the water.
420HOA I would like to know if yours runs any better with the larger headers. I didn't want to spend the extra money for them not knowing if they would help.
2 blade is 5/6 mph faster on mine.
Check the strut angle and location. The rear end of the strut barrel is 23.5" from the transom on mine. The new strut was also made so that the tip of the prop blade is about 5/8" from the bottom. The v-drive is just about under the edge of the dash.
