bocco
- Mar 8, 2008
- 2,183
- 2,297
OK, it's finally time to do a valve job on my 1997 Gen VI HP500. At 400 hours most people would say I'm past do. The last time I R & Rd a set heads was 1974 so I have a few questions since I plan to do that part my self.
First off my compression reads between 165 and 172. Book says 175 so I think I'm OK there. Spark plugs look good also. I have never had to add a quart of oil to this motor. One oil change per season. About 100 hours on these plugs.
I have a local machinist to do the heads. Of course the first ting to replace is the valve springs. He recommends that we pick the springs based on the cam specs. Probably from Comp Cams.
My first real question is which gasket set. Summit has a Fel-Pro Marine head gasket set which is way way cheaper than the Mercruiser deal. It looks like Mercruiser only sells the full engine kit but it's around $1175.00 which is just outragious. Is there anything wrong with the Fel-Pro set?
Next I want to replace the head bolts with a stud set. Seems like cheap insurance. Am I correct correct that this block has blind holes so I don't need to worry about thread sealant? Do I need 12 point nuts? Looks like that's all ARP makes. Milodon makes a hex nut set. Not sure about the quality difference. Price difference is minimal.
Finally, Lifters. I think I should replace these also. I could just go with what ever is recommended with the valve springs. It looks like the OEM style only comes as stock replacement so the tie bar style seems like the way to go. Any opinions on which is best?
Thanks in advance.
Thanks in advance.
