ElAzul
Well-Known RDP Inmate #211
- Oct 4, 2007
- 4,891
- 12,656
Click here and good luck
http://indycompetition.com/engines--engine-parts.html
This is a good deal...
Cosworth Ford DFX engine - $30,000
But the problem with it is that a working CPU for the DFX is almost impossible to find. They were built in pre-microprocessor days, and operate with TTL logic.
Many of the remaining CPUs are crash damaged units that have been repaired. The circuit boards that have been fixed are often unreliable. The same issue affects rebuilt Ilmor (badged as Chevrolet) IndyCar engines of that era.
New harness with motec yo
Sounds like old eprom type stuff or not I have no clue what I'm talking about hahaCrank triggers and other sensors on the Cosworth have to be replaced for that. It's not as easy as one might think.
Another issue with legacy CPUs/ECUs is that the engine management and chassis sensor telemetry is communicated to legacy laptops that are running MSDOS software for the task. These programs won't run on 32 bit operating systems.
There's a shortage of these computers and the software. Again, changing the sensors and telemetry to a modern system requires effort and expense. Most legacy chassis sensors use analog values, and the ECU has analog to digital signal converters.
The ECUs were built with TTL, transistor to transistor logic. These platforms use integrated circuit chips, resistor/capacitor circuits, inductors, and other legacy electronic functions to operate with Boolean logic. Microprocessors and CANbus did not become commonplace until the mid 90s.
Many owners of classic race cars want to keep the vehicles in their as raced configuration for historic accuracy. If they have, for example, a March 84C IndyCar, there are only so many parts available to restore them. The Pi Systems electronics and telemetry of the 80s are increasingly rare and hard to find.
Yeah that's what I meant hahaThe systems do use EEPROM chips. They hold read only memory information.
Reminds me of the ancient laptops McLaren reportedly still has to use to connect to, and maintain, the F1 super car
On that note @rrrr are they recapping the Lucas CD boxes I saw on there as well? Indy/F1 stuff is legit fascinating to me. Whole other world of performance and tech I know little about
I don't know about that specific system, but I'm going to guess a CDI module is much easier to modernize than an ECU. The CDI module is pretty simple. It's basically a capacitor bank, with an external trigger from a crankshaft reluctor that drives MOSFET amplifiers, and they fire the capacitors.
I quit working on TTL electronics in 1994, and went on to other things. My memories of how they work has faded, I'm now just a Viejo Gordo.
It wouldn't be a huge deal to convert to modern motec, even the crank/cam triggers. Might possibly be able to retain the existing trigger system even. You'd definitely change to modern injectors as the old ones were pretty archaic, that may pose the greater amount of work as the injectors on it are most likely "pre standards" in their dimensions and mounting.
I have retrofitted some pretty weird engines over the years. Not the end of the world, an nothing a little money and machining can't solve
Edit: Also forgot to add that the TTL vs Microprocessor issue is somewhat irrelevant since all modern EFI systems have continued to use the legacy TTL 0-5vdc digital and analog inputs even though the microprocessors themselves operate at much lower voltages, they have interface circuitry that translates the 0-5v sources to voltage levels accepted by the computer chip itself. This is probably due to the fact that there was an abundance or sensors already designed to operate at TTL standards and it was much easier to to just build an interface into the board and use off the shelf sensors than to create thousands of new sensors from scratch.
I'm just reporting known issues with legacy Cosworth and Ilmor engines. I suppose a lot of that is driven by period correct restorations.
If you take a look at the engines and cars for sale on the Indy Competition Services website, you'll see that many of the ads state an ECU is or is not included. It's among the first questions a buyer will ask.
Personally I'd rather have modern electronics hidden and keep the mechanical bits happy and running properly over having some funky old computer and associated components that end up failing and causing mass damage
What's kinda crazy to believe is that we are now at a point where "period correct" includes computers and electronics
Sweet baby Jesus!
A two stroke?
Sweet baby Jesus!
A two stroke?
Indeed, I am at a loss...no idea what that monster is!?!?!
You work at AJPE? I've torched a few sets of his heads and more
Can't leave out Brad Anderson, Dan Olsen and a slew of others but yes Alan is the man. Always wondered what they would have accomplished if Blaine was still alive.Alan Johnson is an amazing man, imo!
I do his shipping, receiving and inventory. We’ve been friends for years so I went to work for him after retiring from SB CountyYou work at AJPE? I've torched a few sets of his heads and more
I consider myself fairly well educated in engines in general, never seen a 2 stroke V8!
Thus again my mantra is complete for today, pay attention enough, and you will learn something every day!
Details please JWR!
A good friend of mine had a 2 stroke V8 Evinrude outboard motor in his sand car.
