pronstar
President, Dallas Chapter
- Aug 5, 2009
- 34,474
- 40,924
Just installed it this weekend
Took a little longer than the "installs in one hour!" claim, but not too bad.
All I had to do was run power to it, and then T-tap into the existing lines on my existing bags.
If you run airbags, this thing rocks.
The way it comes, it can control two airbags independently or paired together. With an add-on option, it can control up to four airbags, independently or paired together.
Cool thing is, there's nothing to install inside the cab - the control module is wireless (2.4Ghz), and can even be used outside the vehicle.
It will automatically hold any pressure you want, and even has two memory presets. Just set it and forget it.
If you want true onboard air to inflate tires and other things, then this isn't the setup for you. The compressor is very small, perfect for airbags but not good for a tire or anything large.
BTW if you want some killer long-travel airbags for a Dodge or Ford, Carli's are the shit. Donut-style bags severely limit wheel travel and don't make sense unless you're stock. Long-travel airbags have a full 12-inches of travel.
Here's a link: http://www.thecarlisuspension.com/dodge-ram/components/longtravelairbags.html
