=River Perfection=
- Dec 28, 2007
- 552
- 537
f
Geoff
Geoff
I kinda remember $50/day, pricey.
I dont know if HD has the 3k. The 2k is on the website @ 50/day. I only need it two days. My hook up is 50 amp.. but only have one AC so I will use my 30 pig tail adapter. Love to find a 3k I could rent. Gotta be somewhere.
Sounds like 2x2K's is a 100 bones a day. (lots of crankcases to maintain in this config)
What BTU is your AC unit?
UD
Steal Javier's 3000 gen [emoji2]
A single 2k will not run the a/c.
I know there are some who have done it but it has to be near perfect conditions which you not have 98 percent of the time.A/C needs a hard start capacitor everything off in the trailer that takes power,cool day at sea level for gen to make the most power,etc,
I rented a Honda 3000 at United rentals about 5 years ago, don't remember the cost.
Let us know what they rent for.
and you are right a single speed frame genset on a briggs engine will burn through tons of fuel as wells be a roaring bastard all weekend - you may be raped by your neighbors if you end up running it.
Dirty power yes- all the el cheapo 2 pole exciter based lawnmower gensets run low voltage under high load and high voltage under low load.
Will everything live if you do it - probably, unless your AC is particularly hard starting. How many BTUS? 30 amp connector or no?
As long as you have a buddy to help you lift it go for the bigger single genset. I have a yammie 3000iseb(with boost) and the 2 hondas and vastly prefer to take a single genny if I can move it.
UD
Only if you want the whole campground to hate you, loud as hell. See 2FF above^
Honda 3000eu is what you will want to get they are quiet and reliable.used ones can be found for about 1200 and up and worth every penny.
The 2000s can be parralled to make 4000 watts but you are limited to 1 gallon of fuel in each gen which may not lastlong running a/c.
The i3000 handi is the best bet. The 2000 is minimum. The i1000 will burn out your battery charger. The i1000 should only be used with use its charging cables.
