Issue with Bravo 1 prop
Husqy510
We recently rigged a 26 Howard cat with a new in box Bravo 1 outdrive. We then installed a new Merc prop with a new Merc installation kit and the prop seems to wobble on the shaft.
Any ideas?
McKay
Possibly the wrong hub. Post pic of the prop shaft and hub.
spectras only
Any ideas?
I have two of those and they wobble with varying degree. Only a prop pro like BBlades could fix that. These props are cast S/S not CNC'd like some more expensive ones. You can rotate the bronze insert into the hub at four different insertion and see if one of them will result in a somewhat less Wobble. In the meantime, get a dial indicator and check if your prop shaft runs true.
Here' one of the two props I have on the lathe to demonstrate the wobble.
Husqy510
Figured it out. The rubber sleeve wasn't all the way in so the prop wasn't seated all the way. I pressed the rubber sleeve all the way in and it bolts up nicely
