bocco
- Mar 8, 2008
- 2,183
- 2,297
So I tried a leak down test yesterday to see if I could gauge the condition of my motor. Watched a bunch of videos and read a few online articles. I ended up with a lot of questions.
The motor is a 1997 500HP carbed gen 6. It has about 330 hrs on it. Still has the wire seals. It runs great and pulls strong right up to the rev limiter. My only reasons for doing the leak down test id that I read lot of stories about valve spring and valve issues with these motors. Also I just wanted to learn how so I bought a tester from summit racing. Both gauges on this tester read PSI so you get to do some quick math but it's easy.
The process I attempted was to warm up the motor first. Then pull all plugs and test each cylinder at TDC starting with number one and then rotating 90 degrees and working through the firing order. I got numbers all over the place and I'm not sure if it's how I'm using the gauge or if the engine cooled off to much which seems hard to avoid. On the slightly low reading I could hear air at the intake. On the bad readings I could hear air out the valve cover. But these came later in the process and I'm not sure if it's temp related.
I've read different opinions on TDC vs BDC. Also whether to dial the left side gauge to the correct pressure then plug the gauge into the hose from the spark plug hole or hook all of the hoses and the adjust the pressure and take a reading.
Sorry for the long post.
