Leaking cavitation rod seal???
Froggystyle
The greased fitting that goes into the hose on its way out of the boat is dripping badly.
Any way to tighten it, or is it replacement time?
Most of the time they are a rubber lip seal, occasionally they are stuffing. If it is the rubber lip seal call up glenwood and order one, they aren't very much money.
Froggystyle
Thanks! So I gotta pull the whole rod then obviously. Boo.
nrbr
Bergeron marine makes a rubber collapsing boot that replaces the seal deal. Just 2 hose clamps hot ticket. It takes a different thru hull fitting but it looks and seals
djunkie
Broke mo fo
Did you try pumping some grease in it? All my zerks leak at the beginning of the season until I fill them up with grease.
