DUNEFLYER
The original DUNEFLYER of RDP 😁
- Dec 22, 2008
- 699
- 1,518
Who is our local LED lighting guy?
Thanks for any info.
These are what I used in mine.
LED High Bay - 150W - 21,750 Lumens - Hook Mount - Tempered Glass - UFO Series - UL+DLC
Description The UFO LED High Bay is the best replacement for both industrial and commercial applications. The high lumen efficacy reduces the inefficient bulbs up to 400W MH and can be easily installed in most areas by a hook mount (default setting). The fixture also gives you complete control...greenlightdepot.com
View attachment 1063342 View attachment 1063343
I did the 4000k. I bought 3 initially off Amazon to see if I liked them because of the easy return policy. I liked them so I ordered the other 9 from them direct. I would definitely use them again. I have the lights on 3 separate banks and they are on dimmers (10 volt) too.This is what I am looking for, do you like what you have? Would you change light color (what color did you go with)?
Are these best bought online or do we have a resident lighting guy on here?
UFO lights for the win! Eight 21k lumens 5000 for a 30’ x 60’ barn with 18’ peak. Daylight anytime. Liked them so well I bought 2 more for the outside, in my RV lean to.These are what I used in mine.
Planned on doing two separate circuits then figured I’d very seldom use only half the lights. Decided to do all on one and save the wire for another circuit later on. Still very happy with the setup.My garage is 52 x 25, so I went a bit on the overkill side of things but I'm very happy with how bright it is. I have the 10 lights on 2 circuits, so I can switch on just the center 4, just the outer 6, or all 10. For normal use just the center 4 provide plenty of light.
