steamin rice
No Bad Days....
- Dec 20, 2007
- 3,867
- 2,162
Most people are aware of the issue with a bunch of Livorsi GPS speedomters - The original design used an antenna that is battery powered, and eventually the battery will go dead. Some people have been able to change the battery inside the antenna and their speedo will keep working, but a lot of people have tried this and it doesn't work because the GPS receiver will lose it's programming eventually when the battery is dead.
Livorsi offers a battery-free replacement antenna for about $200, but on their website they state that the speedometers with the molex type 3 pin antenna connector aren't compatible with the new antenna and can't be repaired. My speedometer is one with the 3 pin molex connector, so for a few years I have just gone without a working speedometer because I didn't want to spend the money for a completely new monster GPS speedo.
I started doing some research into this, and found out that what Livorsi says is complete BS. The speedos use a standard GPS signal, called NMEA0183. This means that any GPS antenna that is compatible with NMEA0183 can be used. Also, the 3 pins on the molex connector on the gauge are for 12V, ground, and the GPS signal.
I found a 12V replacement GPS receiver on Amazon.com for $99, which looks to be the exact same unit that Livorsi is selling for $200.
Here is the GPS receiver that I bought:http://www.amazon.com/Sierra-Intern...&redirect=true&ref_=oh_aui_detailpage_o05_s00
Some people have used a Garmin GPS receiver which works fine also, but the Garmin units run off of 5V, so you need to also wire in an adapeter to convert 12V to 5V. I chose the Sierra receiver because it is a direct 12V connection for a clean install.
Yesterday, I pulled my boat out of the garage and wired in the new antenna. It worked great and was an easy fix. The new antenna has 4 wires on it, red, black, white, and green. The green wire isn't used for the speedometer, so just connect the red to 12V, black to ground, and white to the GPS signal connection on the speedometer. If you have the 3 pin molex connetor like I do, I think this actually makes for a better install. Just match the three wire colors (red, black, and white) from the new GPS receiver to the same color wires from the 3 pin molex connector. I soldered and heat shrink wrapped the connections from my new antenna to the molex harness for the gauge. See below for pictures.
