Yeah was going to do that as a last resort. Closest i found was called hella connectors. but top part where it extends out was full width. No Luck on aeromotive or OrvacSomething you can do, bend the tabs that hold the wire out. Put the new wire in, bends the tabs back. Solder it and heat shrink over it. It would be time consuming but it would look nice when you’re done.
Google is your friendYeah was going to do that as a last resort. Closest i found was called hella connectors. but top part where it extends out was full width. No Luck on aeromotive or Orvac
Pulling the insulated section out is cake, the only complication will be the actual copper strand and crimp there. But as OD1 said just clean that section up then solder a fresh wire in there, then heat shrink.Yeah was going to do that as a last resort. Closest i found was called hella connectors. but top part where it extends out was full width. No Luck on aeromotive or Orvac
Google?? Why didnt i think of that before posting on a forum.Google is your friend
Thanks, but those wont work either.Yours if your local to corona. If not pm me your address and I'll send them through usps View attachment 711917
Sent from my FRD-L14 using Tapatalk
I have the ones with the thin centers alsoGoogle?? Why didnt i think of that before posting on a forum.
exactly what i needI have the ones with the thin centers also View attachment 713236
Did these terminals work for you? I’m looking for the same one shown in your original post. The ones waffles posted look similar besides the small alignment tabs on the bottom of the spade.exactly what i need
