Rust vs Rot.....this is the question.
It's been 2 full years since I last used my my boat. The lakes in south- central Cali (i.e Nacimiento) are dry, and I can't find the time to make it out to the river. I live less than 15 minutes from the launch ramp in Santa Barbara harbor, but my boat has never seen salt water.
After 2 years of no boating, I've decided it's better to get some use in the ocean, rather than let it rot on the trailer.
The problem-question I have is this...... what to do about my steel trailer? Unlike the Mercruiser, which has some corrosion resistance, experience tells me the trailer will be a probably be a rusty POS in 2 seasons or less, even if I'm diligent about hosing it down every time. I've been looking for a used galvanized or aluminum trailer for several years, but no luck so far. A new aluminum trailer is pricing out at around $5K with tax. Hard to justify buying a $5k trailer for a $10K plus boat, that hardly gets used. Even though my rig (23' bowrider w/ Merc Mag 350 and Bravo 1) is modest by any standards, it's mint, sharp and shiny (i.e looks good to people who don't know anything about boats.) and i don't fancy the idea of running around on a rusty POS trailer, with chrome peeling off the wheels.
Questions:
* If anyone has a lead on used aluminum or galvanized trailer that fits a 23' v-hull let me know. I have an ad in the classifieds.
* Anyone else dipping their steel trailer in the salt? How long before the average steel trailer self destructs?
* Has anyone used a sling launch? I've watched a few guys use the sling and a hoist, and it looks a great way to F***up your boat fast, if you're not careful.
* Are you using anything in addition to fresh water flush after a run in the ocean? i.e spraying "MerCruiser Corrosion Guard" on the outside of the engine, for example)
* If you don't have closed loop cooling, how many "engine hours" before bad things start to happen on the inside of your block?
* Do I need to install additional anodes on my boat. (I found a Merc service bulletin on this subject, but it a long a complicated test procedure - http://www.marinemechanic.com/merc/distributors/mercurymarine/sterndrive/corrosiontesting.PDF)
* From the Merc site - "The MerCathode should be tested annually by an authorized dealer for proper operation"...anyone have the do it yourself version?
Thanks to anyone that took the time to read this long winded post....
Questions:
