Looking for hatch hinges
SpectraPat
Any one know where I can pick up a pair of these hinges?
SpectraPat
Thanks, but not the same. This type requires cutting a notch in the fiberglass. I’m trying to avoid that. Thanks again
74 spectra20 v-drive
Hey Pat, you may run into an issue with those, not sure if the spectra will have enough room to swing up inside deck. I used these from Eddie Marine... I made a 3/8 plate to hang the hinge in and spread the load out.
SpectraPat
Thanks!
Gripside80
Those hinges are made by Stan at Schiada. Not a part you can just pick up.
tony
That was my 24 schiada and I had Scott Kornaski make the hinges and the fiberglass hatch while it was getting the interior done at Bill Sturgis place.
Gripside80
Nice. Love that 24. One of the nicest. Lee/Stan makes the exact same ones. Regardless of who makes those.... it’s not a “buy it now” part. They are made to fit each boat/hatch perfectly.
FrznJim
Get out the saber saw and make your own. That’s what I did.
SpectraPat
You can try these if you have the room. I’m modifying the ones I bought. Good luck!
Water Romper
These look pretty good. $70.00 for the pair seems reasonable. would you mind posting a few photos of your install? Thanks!!
