- Feb 13, 2008
- 20,524
- 17,384
So, Ive been really busy with helping out around a truck shop to trade a little labor for fixing certain things on my truck, and a new gf, and doing stuff around the house and all. But, I was able to get away and go to Naci for 9 days. The boat ran great! Until this last Friday when coming out of Las Tables, it started slipping out of forward. After pulling the shifter out and tightening everything up and check the shift linkage I could check on the water, I conceded and had my buddy pull me all the way back in. Turns out that I spun a prop hub but the sound wasnt just an RPM increase like a prop hub would be so I switched props, dropped the lower unit to check the teeth on the shift shaft on the lower unit and the shaft itself. Both checked out fine so I dipped it in the water and it was still sounding like it was jumping out of gear even though the cable was as far forward as possible.
I havent had a chance to drain the oil yet to see if there are shavings in it but I think its either the forward gear or dog is toast or the arm at the top of the shift shaft has slipped and spun even though it will still go into reverse.
What do you guys think from that description?
