HALLETT BOY
- Oct 12, 2007
- 6,777
- 9,983
Anybody have a trouble- shoot chart / diagram for a mefi 3 system ? Specifically the IAC circuit ?
Can’t get the IAC to respond to scanner request . No idle flair on initial engine start is my original complaint. Engine stalls immediately after start .A Mefi3 is a pretty stupid simple computer. I love them for that. But it also means they usually wont tell you whats wrong. You have to troubleshoot your engine more like its carbureted vs injected with the only major difference being how they respond to vacuum leaks which is the opposite of a carb.
What are your symptoms?
There is an IAC filter, it looks like a piece of scotchbrite, pull that out and see if it improves. Sometimes it's the simplest things.Can’t get the IAC to respond to scanner request . No idle flair on initial engine start is my original complaint. Engine stalls immediately after start .
This system is on a 565ci with 3.3 whipple . Was working last year . Pintle on IAC is extended all the way closed . Can’t get scan tool to retract , tried new IAC , no changeVery early merc TBI motors did not have a boss for the IAC in the intake manifold. The IAC was there but it did nothing because it went to nowhere. Make sure your motor is not one of these. They are easy to tell because they look like a TBI is bolted to a 2bbl intake manifold via an adapter plate.
Once ruling that out do the iac filter removal/replacement as mentioned by @4Waters.
Beyond that you are really narrowed down to it only being the IAC, wiring harness, or ECM in which case, 99% of the time its the IAC.
It worth mentioning that I always start with checking fuel quality and sparkplugs/compression when there is a runability issue. It's worth ruling it out at the very get go so as not to be chasing your tail down the road.
Check circuit integrity back to the ECM. I prefer to unplug both ends, supply 12V to one end and see if the other end will illuminate an old sealed beam headlamp. If the circuit is intact, and both the old and new IAC have no function with scanner commands, I’d condemn the ECMThis system is on a 565ci with 3.3 whipple . Was working last year . Pintle on IAC is extended all the way closed . Can’t get scan tool to retract , tried new IAC , no change
The problem with that is I can’t physically reach the ECU , the header and supercharger are in my way , and I’m not that flexible anymore .Check circuit integrity back to the ECM. I prefer to unplug both ends, supply 12V to one end and see if the other end will illuminate an old sealed beam headlamp. If the circuit is intact, and both the old and new IAC have no function with scanner commands, I’d condemn the ECM
Thisre-read post 8.
just beacuse you replaced the IAC doesn't mean jack if the new one has a different pin out.
furthermore if you can't get about 50ohm across each pair of your original IAC this PROVES the IAC is bad.
