Mercury 450R - any issues ?
Toffen Gunnufsen
Hi!,
At last I have the possibility to order a V8 450R for my ol Phantom 25. Being a festival promoter has not been easy the last year.. Totally lock down.
The 400R has been a fantastic engine, but this season is the last with warranty.
The 450R has been on the market for a while now. Any issues you know about?
Thanks!
Cheers Toffen
McKay
Some broken lowers is about all I've heard about.
McKay
Lots of broken shafts and lost 6000 dollar cleavers in lake. DCB and Eliminator both putting tabs on boats to help. Mercury has a new shaft now that is supposed to be better.
I think DCB only put a tab on one with 450’s. Have not been seeing any new models coming out with tabs.
McKay
Really. See if they will build you a m33 with 450s and no tab. Nobody likes to talk about it but go ask Barrett marine how many they have fixed.
Ya have a few buddies with 33’s and 450’s. One two doors down. No tabs on them.
McKay
Show me more than one of the ten or so 33’s built with a tab.
And I’m not saying there isn’t an issue with the lowers. I have been behind the wheel of a 450 boat that broke a lower on me and I was being very easy with it only doing 70 or so.
BIGRED9158
I also know mercury has some lawsuits about people driving at high speeds and breaking prop shafts and people getting seriously hurt and killed that is why you see eliminator not making another 25 with 450r they won’t do it to much of a risk to get sued
Sonny
I just took delivery of a 2021 Statement Cat with 450s.
Hoping someone will explain what effect the tabs have on the lower situation.
Thanks
Sonny
Pic
prorider
Thanks
A tab helps them roll over easier. Some have lots vibration on takeoff if you give it more than 4000 rpm. They have all that exhaust dumping out around these cleavers which doesn’t help.
HighVoltage329
I believe hull bottom design has helped with some issues.
Thanks
I think your hull design is going to roll on plane without having to apply much power if it's like my MTI.
McKay
Agreed, the new lighter, longer cats get on plane so much easier with very little bow rise or cavitation.
Sonny
Understood. Yes, rolls right over with little to no cavitation. 14.75/15/35s Mercury Props. It did cavitate a little more with the 15.00/15/36s
Sonny
Anyone making a Carbon Fiber Cowl for the 450s yet? With a design to increase air intake?
HCP3
martycar9
New Member
My buddy has an MTI with two 450R's. We noticed there was a decent difference in the coolant temperature and pressure between the two (144 vs 153 and 10PSI vs 14PSI). Does anyone know if this is normal?
lake p.a.l.
I'm no expert on 450s but I did notice the trim is way off between the 2, especially at 68mph
McKay
My trim seams to be spot on with my 450's. However yes I have one engine that runs slightly warmer and a little less pressure but only at idle. I have a spare set of lowers so I'm going to try one of my spares to see if there is any difference.
One other thing of note Mercury early this year started using a different prop shaft. There is a date on all of them and the new ones say Revision B.
DaveC
Car-boat motors
I talked about the prop shaft issue with Eliminator and they said the prop shaft failures are due to severe prop cavitation
The engines are mounted very high for performance. When the boat rolls over while trying to plane they get prop cavitation causing stress on the prop shaft. The prop shaft does not like that vibration and will eventually fail.
If the engine was lower they would have no cavitation but then the boat would be slow.
They put a tab on it to get it to rollover faster reducing cavitation. But that is so the engine can be mounted at the correct height.
In most boats the best MPH is found when the engine is mounted very high. I am told for mine the peak MPH is found with the prop shaft at 2” above the bottom. That is very high.
The other solution is adding a jack plate like mine. I put the engine all the way down until it rolls over then move it up. I have zero cavitation
McKay
I talked about the prop shaft issue with Eliminator. they said the prop shaft failures are due to severe prop cavitation
I seen STR came out with a version of their engine brackets that adjust. Have not seen them on a boat yet.
mbrown2
This is the route I went....I had a tough time rolling over with more than 2 people in the boat and lots of vibration....I had bobs machine jack installed and it works great...much easier to roll over now.
TVMNick
You will see variance widely with water pressure depending on several factors. I would say as stated earlier the variance in the trim setting would be enough to cause that discrepancy in water pressure. Those pressures I would say are normal for that speed, 90+ MPH and those pressures should come up near 20+ sustained.
McKay
Ya mine is strange. I don’t get hot. But sometimes I’m cruising at a 100 with upper 20s psi and then next time same speed same trim I’m at 15 psi. Need more seat time to figure it out.
lighter load allowing the boat to run more out of the water?
TVMNick
Could be? Need to burn a few more tank full’s to get a good feel for it. It has 200 gallons so takes a bit to get through it. Headed to powell next week so much easier to stretch her legs.
I've noticed as I burn off fuel my boat settles on its back steps better and the water pressure comes up, I'm sure with your even bigger tanks you will notice this more than I do! It will be interesting to see if the 18 rake props make a difference as well. I wish I could have ran my 18 rakes at Havasu first for a direct comparison but with the air density difference keeping the bow carrying will be even more important at Powell.
Sigus
Above the wet spot
I am now running the 18 rake from 15, boat handles great and water pressure is more stable. Fuel efficiency has fallen off with the 18. Anybody wanting a set of 36 15 15 1/4 give me a shout.
lake p.a.l.
Stopped by Performance Boat Center yesterday & spoke with service manager for a bit. Heard 2 cats with 400s broke propshafts on Sat & 1 with 450s broke a propshaft on Sun. All boats mentioned had the new 1 piece "updated" latest model shafts from Mercury. I sure hope nobody gets hurt. Losing a propshaft at speed could be deadly if driver does the wrong things.
Each of those boats lost their high dollar Mercury props, sadly.
Mercury has denied several claims saying the boats are not setup properly etc.
Thankfully I'm not looking to re-power right now.
McKay
Thanks for the update Rob. That's shitty to hear they are still breaking with the updated shafts.
El Guapo
HAVING FUN
The 450’s are having Popet Valve issue. The retainer clips are breaking and the popet internals blow out. If this happens, you lose water pressure in the motor. You can still run it to get to the trailer, you just have to go easy and trim to get as much pressure as possible. All Popet valves from Mercury Racing are on back order. I’ve already been through one on my port motor, warranty took care of it. I had AJ order me an extra. They are very pricy tho! They run around $900.00 per valve.
lake p.a.l.
Heard the same thing. How many popet valves per motor? Are they easy or difficult to replace? What do they actually do?
Just trying to learn
TVMNick
Do we have a thread on here with service info and how to info on these newer merc outboards? I think there are several of us that end up having to do our own service work for various reasons and a thread that details that work would be beneficial to us all. It's crazy to me how difficult it is to find specs and details on these motors.
McKay
Nick I now have a service manual that you were asking about a month ago. Also I have AJ putting together a parts list of common failures for me and randy, we are going to buy all the spare parts from him so we have them with us all the time.
TVMNick
Awesome!! I’ll come over one of these nights and dig through it. AJ mentioned that to me when I was down there last and said he’d get me a “kit” built at some point. You and Randy are going to have enough stuff between you to power a factory race effort soon enough!
prorider
Damn disgusting mercury hasn’t fixed this problem. Lots 6000 dollar props in the bottom of lakes.
TVMNick
Anyone have any updates to this thread? I broke one prop shaft this season and warranty covered the shaft and the prop. I'm now hearing motor mounts are failing and Mercury Racing has an update part # for the new motor mount but haven't been able to confirm that.
I'm at around 69 hours on my 450s, who has the most hours on theirs?
McKay
I’m at 93. Yes there for sure is a new motor mounts out. I have seen them being installed on 450’s that had about 130 hours on it. I’m going to find out the info on them as I am painting my cowlings this winter and will be pissed if they get chipped up in the middle of next season from the tie bar mounts banging into them.
TVMNick
I'm interested if Mercury will allow the new motor mounts to be installed if the current units haven't failed. Mine seem fine, but I feel the same way, I'd like to get them replaced before my cowls get beat to shit because the mount fails.
Have you found any data on prop shaft failure rate with the updated "Rev B" shafts? I know you have had good luck with yours and been running it heavy and hard.
prorider
Just broke my second shaft last month. So that makes both motors now. Around 140 hours on mine. Also lost a alternator.
