steven vaccaro
- Dec 20, 2017
- 26
- 2
I would scan the engine with a current scan tool. To me that alarm is VOLTAGE. Also it would be great if you tell what app - meaning what make - model and year and engine serial number you have here - Is this a Mercruiser ? Or a mercury outboard ? Is this a Volvo penta with Econtrols or this an Ilmor with econtrols or ? No to sound like a jerk but we have to know what you have here ? Other wise its throwing darts at a huge dart board.
Guardian mode aka limp mode aka power reduction mode and its Voltage
you need a current scan tool plus know how to use it or take it in to a Merc racing cert shop that uses the G3 scan tool. Do so before you wreck your pcm 555.
Solid info here --- the scan tool is only as good as the person using it. Most people including some boat mechanics think just because there is NO fault codes displayed when scanning marine engine --- that all is ok for the fuel injection management sides of things. THIS IS SO FAR FROM THE TRUTH.
Usually you can touch the screen just for that alarm and it will give you more details.
If for some reason you started it with the charger connected, and it saw more than 16 VDC, it would be high voltage. If it’s below 11.5 VDC, it’ll show low voltage.
If you had just charged the battery enough to start it and were just idling, the alternator is probably not going to keep up with engine/boat electrical load AND have enough to charge the battery until the engine is over 1000-1200 RPMs. The output curve of the alternator is steep vs RPM.
If you do have your dealer scan it, all of the parameters for each alarm are in Freeze Frame Data, and they’ll be able to tell if you were running or not, what gear you were in, and where you had the throttle lever, as well as TPS, oil temp& pressure, spark, MAP, RPM, etc.
Hope this helps.
