Tractorsdontfloat
- Jun 22, 2017
- 727
- 2,294
Well, ladies and gents, the original version was pretty well received. And I have been asked to either continue it, or do a new one for this season, so here is the start of version 2.0. if you haven’t read that thread, feel free to look it up and enjoy. If you have, most of this should make sense.
The intent here is just like the original. To tell my story. I will gladly answer any questions you have. What I do for a living, to me seems very mundane and ordinary, but I understand not everyone understands what it takes to grow food for the world. I am not trying to talk down on anyone or belittle anything, just telling the story. So, if you have any questions, regardless how trivial you think they might be, ask away and I’ll try to answer. And I hope this becomes enjoyable to read and we learn something along the way.
Currently, the snow is almost all gone around here already, thanks to a warm spell and a decent rain. We continue to work in the shop getting equipment ready for spring. Lately, it’s been mostly semi trucks and trailers. Brake work, and general DOT inspection work to keep them on the road. Today we were servicing one of the tractors, and starting to mount the liquid tanks that will haul the fertilizer during the planting process.
This set of tanks is made by Demco, and is their side quest series. They mount on the tractor using an arm that mounts to the frame in front of the cab behind the front wheels, and on a shaft that mounts with a bearing directly onto the rear axle of the tractor.
The initial hub that mounts to the rear axle.
The plate that attaches to the frame in fron of the cab. And the arm that attaches to that plate. Note the arm reaches up higher to allow clearance for the front dual tires.
This is the rear shaft with the bearing hub mounted to the initial hub in the first pic.
The tank hangers on the front of the tank mounted to the front beam.
A couple shots of the tube that the rear shaft slides into to hang the back of the tank.
And last, a shot of the left tank hanging on the tractor outside the tires.
