RVRKID
- Oct 17, 2007
- 6,062
- 5,627
I don't know the exact answer, but our place has two systems. One is controlled by a typical shower valve and normal water pressure and it drips more than it mists. For this reason another system was added after and uses smaller, piston mist heads and has a pool pump in line to supply pressure. That system mists beautifully.On an unrelated note, what kind of pressure do you need to run misters? Just you joe blow diy kits?
I did that 20 years ago on my jet bote. It worked, but made such a mess of the boat it wasn't worth it.I had an idea of creating a system that easily mounts to a pop up canopy, submersible small pump in the lake or river, powered by a solar charger.
The pump is what’s holding me back, can’t find one small enough to supply enough pressure.
Great idea. That just sent me down a bit of a rabbit hole.
