MMW cavitation plate vs tunnel tabs
Husqy510
We have an 03 26' Howard cat which we rigged for the 1st time last year. It has a N/A 540 which made about 720 on the dyno (probably mid 600s with accessories and exhaust). Currently we're spinning a 28 prop which works great once on plane, but with 4 adults it struggles to rollover. I was thinking about adding a cavitation plate to the outdrive or fixed tunnel tabs. I'm leaning towards the cavitation plate because I don't want to drill a bunch of holes in the transom. I'm looking for something that will help with coming on plane and decrease the load on the outdrive.
Any suggestions?
2FORCEFULL
i've had great results with tunnel tabs... they handle ruff water better as well as get on plane better...they stop it from kite ing off wind rollers
$hot
To say what? :)
would be great to see some pics!
Simply put, there is zero downside to the MMW wing plate, and it’s 300$ and a couple small holes drilled into your drive. I’d definitely try that first.
However with your hp and boat, wonder if your X isn’t a little too high.
Stock lower or a shorty?
Husqy510
Here's a pic of the transom. Pretty sure the outdrive is a stock Bravo
Husqy510
The boat drives great and has no porpoise. I'd actually like to try a 30pitch because the motor pulled 5600rpms easily and I'm sure I could trim it up a bit more, but I assume that would make it even harder to get on plane
ONE-A-DAY
Try a max machine works wing plate, cheap, easy to install and makes a big difference before you go and spend more money and more headaches than you need to.
2FORCEFULL
LOL... after looking at the transom, I have the fix,... but it'll just start the shit show of yard dogs barking....
2FORCEFULL
the getting on plane problem is the big noches in the sponsons
THE Cat Sass
I have some experience with the MMW cav plates on a 28’ Speedster. The worked exactly as advertised to help control the blowout prior to flop. That said if you don’t have the low end torque to blow out the prop the plates wouldnt be the answer. It was a game changer on the 28 for sure, I could essentially get a little momentum, set the sticks to 1/4 throttle and it would roll right over.
Husqy510
Just ordered a polished cav plate from MMW which I hope to install on Friday. I'll update the post after we try it
Husqy510
A friend with a lot of experience setting up performance boats mentioned the cavitation plate can add a lot of lift to the transom, drastically changing the handling. He also mentioned that the addition of the plate will require more positive trim at speed. He wasn't opposed to it, but mentioned those potential issues.
Did those who added the plate notice these characteristics?
wet hull
My MMW made a world of difference. Boat rolls over great with full tanks and 2 people. 8 people and full tanks not so much. This is where it changed the game and made the rollover easier and faster. You will not he disappointed.
Husqy510
Thanks, so far I haven't read anything negative, but want to make sure I'm informed.
Yea idk about any of that. The only change i noticed was getting on plane, and that it helped with low speed turns (180°) it helped reduce the blow out of the prop.
Motor Boater
What does the plate look like? I didn’t see it in their website. My 28 Bullett has issues rolling over when it’s loaded down.
2FORCEFULL
I got in this same situation,,, the fix for me was I did a 2'' drive spacer... it made a world of difference, boat handled better all threw the throttle... but the neg. was it lost 2 mph on the top end.... for me it was a great trade because I wasn't after max speed as much as usability
2FORCEFULL
I agree with your friend... could get wierd at WOT pushing the COG forward....
2FORCEFULL
On this boat,... the only person I personally would talk to is Gene...
I can go take a better pic if needed but i screenshot this from another to get you an idea.
