28Eliminator
- Feb 10, 2011
- 11,309
- 11,060
What king of fuel pump is that?
Keith Eckert. It’s a 120gph upgrade for the Gen V pumps.
Looks like a Keith Ekhart (sp). I had one on my Nordic, worked good.What kind of fuel pump is that?
Early AFR castings did not have any additional holes to vent the heads to lifter valley. We made AFR aware of this and they now drill holes in the center of the heads to vent the valve cover area to the lifter valley. If not done this can lead to oiling issues.Can you explain Chris? what would you do differently with these heads?
and what do you mean by "Venting the heads"
I’ve spoken to 3 different “notable” engine builders about it, and 2 just smiled and said “we don’t sell Morels anymore”. The 3rd said he had never seen Morels do that, but he had never seen a set with that many hours on them either.
Does it run yet??
Good results, especially for a family oriented Vee bottom. As predicted the cam is a bit small. Single plane intake 516 flattening from 5400-5600 is giving up probably 40 HP with a slightly larger cam duration wise that would peak 5800-6000 since you have the valvetrain to accomplish that. Do you care for a 28 eagle? probably not. This will pull bitchin from 3000-5000
You fuel distribution goes to hell over 4200... A whole point off bank to bank. Was this dynoed with the boat headers or dry dyno headers?
JT
The heads are only 305cc, and the carb is only a 950 QF on a 555ci deal. We new it was gonna run out of port and carb before it got to 6k, so we sized the cam accordingly (242/650 - 247/637). More runner volume and a real carburetor, and I agree... it would have made more, but it will never turn 6k. I think its a good fit for the boat, and actually made more than I expected. I'm really happy with the TQ numbers!!
The fuel distribution is a result of the DART single plane. Merc originally stagger jetted the carbs to fix it, and it worked pretty well. I've since jetted the STBD side up 3 sizes in both the primaries and secondaries, which was the % I had it at before with the old engine, and it was good. Fingers crossed!! It was dynoed with dry dyno headers.
Dave
Johnson - https://teaguecustommarine.com/em0011/johnson-bbc-hydraulic-roller-lifters-3605So all of this lifter talk got me browsing through Summit Racing. My motor is a gen 6 500HP. Looks like both tie bar style and lifter guide style are available. Any opinions on what is preffered?
Rather than seat pressure, I would be more interested in knowing the nose pressure.When you say you have 200# seat pressure is that confirm as the heads are now, or when it was new? Take a picture of the tip of the valve. Does it have a star pattern? Check pushrods for marks on them in the area of the pushrod that goes through the heads.
