X Hoser
- Nov 2, 2011
- 1,665
- 1,728
I keep getting codes on a Ford V10, F53 Motorhome. (Has the Banks Kit but running stock program).
First Time, after adding fuel. (Not a fill up). Check engine light came on. Tightened the cap and after 3 cold starts light went off.
Then, a few days later, light back on. Codes P0148, possible restricted fuel flow, and P2196, Rich Bank 1. Seem to be conflicting codes? Replaced the gas cap with a new one, cleared codes and seemed fine for the short distance I drove it after that.
Then today I fill it up, make sure the cap is on tight and bam, immediately another check engine light! This time P2196 and P2198. Rich Bank 1 and Rich Bank 2.
A little research online I'm thinking the Vapor Canister Purge Valve may be bad? 31000 miles and not the original owner so I do not know the history whether they "topped it off' each time at fill up or not? It seems to run fine. If left in Drive is seems to bog a little from a stop but then clears right up and runs fine. If manually shift 1,2,3,D no bog.
Any Ford mechanics on here with any advice? Is the Purge Valve a good place to start?
Thanks in advance!
Thanks in advance!
