I am trying to find a cover for an old Neovane water pump(the larger one). I need the actual cover that goes over the impelled. Any help would be greatly appreciated. The part number to the pump is v-105-3. Thanks again Trent
malik, whats your motor set up. blown,turbo etc.
Sangermike's pump would work for you since your just running a N/A big block. If you had a blower or turbos it would be a little weak flow wise.
