Keifer2021
New Member
- Oct 4, 2021
- 1
- 1
I have an Eliminator Eagle 250 with a procharged 540. First trip out ran great day one and two. Third day out and it was making a slight banging noise and hard to idle from the motor. Took it to Eliminator and was diagnosed as loose valves on one side. Valves were adjusted, outdrive was serviced and when it was started up all sounded good. Next trip out boat fired right up and idled well. When trying to take off boat bogged down and would not reach RPM to get on plane until I backed off the throttle after about 10-15 seconds. Once it felt like it kicked in the boat roared to life and had no issues cruising 45-50. On several take offs when boat would come alive it would throw the power steering belt off too. Back on the trailer it went after second trip and its been sitting since. I pulled valve covers and exhaust off and found a small amount of water in the heads. No water in cylinders, no water in oil, compression check is 130 across all cylinders and plugs looks nice and dry. It is a procharged dart 540 with AFR heads, Holley HP efi system, and a dry exhaust system. I'm having a tough time finding anyone here in the High Desert that knows this motor to be able to diagnose it. I have extensive paperwork and build data on the motor which has roughly 100 hrs on it. Please see photos I have included and perhaps this is an issue someone is familiar with. I bought the boat 2 years ago and have only been able to enjoy it one trip for the first two days. This is very frustrating since I am mechanically inclined but not enough to know what to look for.
