Looking forward to this one as well, thanks for posting.
we will do it anyway you want it..........i'll put all the graphics on top of the tunnels if you wish....
the condensed version is if the graphic is put all the way down to the water, it makes the boat look taller...........the graphics are designed to sleek up the boat, make it look shorter(height wise) and longer........putting it all the way down works the opposite.......of course it is graphic dependent......it is pretty much just this style...............and its variations..........when putting it at the bottom, instead of white at the bottom, you end up with more white in the middle, thus making it look taller...and splitting the difference and putting that body line in the middle of all those tapering targets skews the shape.......it also f-s with the blends...body lines catch blend color and you get streaks of the first color down the body line.........but like I said, it is graphic dependent........this was drawn like this to utilize the body line................and of course this is all opinion.....and a matter of style of our graphic designer........the 29 isn't as bad as it has more length and is a little shorter in the rear to pull it off.......hope this explained
that make perfect sense!
