R
Retired Member
Guest
I figured RD gets hard ons over threads like these. This boat pulled in the Robinvale race lat weekend and was clocked at 124mph pulling 2 skiers.
That thing is SIIICKKKK!!!
I got questions.. Lots of questions.
# 1, What's the 2nd handle for on the drivers side? Ballast tank maybe? I'm assuming the push switches on the left foot are for trim?
Switches on the dash? (ingition, fuel? Bildge?)
Any transom shots? I'm curious if they are running tabs, if so parrallel to the water, or to the transom? Outdrive?
And the most obvious of questions.. Any more pics of the motor? I'm looking at the compression side of the turbo's, and following the intake tract. It looks to enter the inner cooler from the backside, and then down through a sheet metal collector, to a intake manifold.. I can't really figure out what that rather large phalic looking tube downwards goes too, but the only thing I can think of is possibly a blow off valve of some sort? Looks to have a throttle linkage attached to it though which is kinda blowing my theory out of the water? More pics of the motor please.
What's the story on that relatively unusual looking setup? Plus of course HP #'s..
My guess is that the phalic is the cooled air out of the intercooler heading down into the throttle body (it sure looks like a throttle body to me, the water lines are in and out on the sides, i bet they are filling the intake plenum on that fabricated manifold from underneath, and what is directly between the top of the intake plenum and the bottom of the intercooler is just a large support.
Looks like a motec dashboard, either they are running a motec or autronic ECU
The more I looked at it, more I started to figure out it was the intake. The back half top of the manifold is covered.
How big is that thing?
I think they are just holding that intercooler up to keep the look of a high rise, but more likely to make it easy to get to the fuel rails/injectors etc.I thought that two, but what would be the point of a highrise intake manifold if you were giong to do it that way? It looks like they built it from scratch out of sheet metal, so why not just run the tubes straight into the heads off the sides of the throttle body / plenum? Why run them way up, and then way back down? Unless their might be some harmonic / tuning benefit to having a longer intake manifold with a side draft intake port? (that's very possible, kinda like a Honda VTEC intake plenum on their DOHC motors)
Or perhaps I'm over analyzing this deal, and they are just feeding it more or less into the heads, and the rest of that intake manifold might just be to hold up the innercooler etc.. and just maintain the "look" of a highrise.. Who knows..
Need more pics.
Couple of running shots of the Force outboard in Parker. They seemed to be running trimmed down most of the time.
Looks to be that way.. There is something on the top of that back half of the manifold, that looks to be plumbed into what I'm guessing is the waste gate on the turbo.. ?? Which leads me to believe there might actually be inlet pressure in that cast aluminum (looks kinda like a blimp) deal that's on the back half of the manifold..
Ah who cares.. when the rest of the pics show up, it'll become alot more clear for everyone.
Those ausie trailers are funky, no bunks its just one big pad, plastic fenders, i'm not sold on them. especially when all that plywood starts rotting from water
Blazen is a 21' as is the red outboard above which used to be the Herbst old boat. It was plowing most likely because they were running some balast.
The 23' Force (which incidently still measures 21' and is legal for world copetition) has a built in swim step. Howard Hoggins has a new 23' with a EFI turbo motor and a 6 drive.
I thought it was the Haigs boat? I swear I saw Howard driving up to the sandbar last year. Also on Force's site they show a picture of it and the pic name was haigboys.
I just talked to my buddy the boat has tabs, a 6 drive and he didn't know what the phalic deal was. He said the guy that owns it has a bunch of ski race boats and they all have real exotic power plants. I guess he has a hauler like Randy Davis and on a race weekend the truck is picked up driven to the site and he has driver for the boat. Sometime he shows up for the races to watch and sometimes he doesn't. It must suck to have that much money.
Haig's is all red and they still have it. When Tim called to have it built Howard has already ordered his all red. The owner of Force told Tim I'm not doing two all red boats add a color, so Tim said give it a black bottom.
Yeah, Noel Griffin. Noel is a character. He was at the river with us last year before Catalina. He pulled Ben last year. We had breakfast with him the day of the Cat race. He owns a boat called "Special Edition", one called "Wild Fire" and now has Blazin' also. Mick, who sent me the pics, told me a story about Griffo driving "Special Edition" in a race side slapping it down the straights at 110+mph. Mick said Griffo is crazy and he won't ride with him again.
I would really like to see a pic of one of those trailers without a boat on it, if anybody has one :hmm
The Aussie trailers are great. They have fiberglass that is shaped the same as the keel, that the boat sits in. They go on the trailer straight nearly everytime. They support the boat much better and would have much less of a chance of any bottom warpage.
What plywood are you talking about? The only wood on the trailer are outside bunks that are there to keep the boat from rocking. Nordic is starting to their trailers like the Aussies.
If they are making them out of fiberglass that's alot nicer, one of my good friends worked for Dunsmore, they gave him one of the aussie race boat trailers that had the full bottom and it was all wood (made a great utility trailer for hauling tree branches to the dump ). I still like bunk trailers better, being able to get to the bottom of the boat to clean it etc, i don't know how tight a fit the boat is to the trailer, but i wonder how it is at retaining moisture in that carpet from being sandwiched in between the boat and trailer shell. :hmm
To each his own, i'll take a bunk trailer any day over that full bottom deal.
The boats themselves are pretty bitchen, i rode observer one afternoon on mead taking Lori Dunsmore for a ski ride in the red outboard, great handling/riding boat.
That boat is a 21'
Cool, you have more pics of it?
That thing is freaking cool! I wonder how it stacks up against say a schiada in the rough stuff.
For those of us that aren't overly familiar with the Aussie boats..
How does it compare to a Cyclone? (I'm getting the impression this is better then a cyclone for rough water?)
Any other hulls of interest from over there I.E. Conley? (sp?)
The Force is the up and coming boat. I am not sure how many new Cyclones are being made over there, since the owner of Nordic owns the company and has Ross over here making boats. Conley's are very fast, but the fastest boat over there is made by Superboat. Basically it's a splash of the Conley with a few changes.
I talked to Greg Houston (owns Stinga, a connoly the boat has won everything) when I was down in Oct for the Indy race. He also drove Merc Force (21' Force with a 1075 package with a 6 drive in the worlds) He said in rough water there is no comparison between Stinga and Merc Force, he said Merc Force is hands down a superior boat in the rough. In smooth water he figuers Stinga would still be faster with the same power.
Connolys, Cyclones and Force will hand any boat built here there lunch in smooth or rough water.
People need to see the race DVD's from AUS. Those boat drivers are nutso as they are flinging those babies all over the place at 95 plus. We race around buoys, they race winding rivers. And they do it doubled up...
That would be exciting as hell to take a ride on one of their courses.:beer
... I have quite a few race DVDs but I need to get a multi zone DVD palyer to play them on anything other than my computer...
Hellbent just won the Robinvale race last weekend and it's not a Connoly, it's a Superboat (although it is a Connoly splash).
Same problem I have. They work in the truck (Eclipse DVD) and the puter but not on the home DVD... Where do you get the multi zone deals?
Ummmmm yeah, http://www.waterskiracing.com/
