no spark intermittent
Discussion in 'RD's Lounge' started by badluck, Jun 12, 2019.
  1. badluck
    badluck Well-Known Member
    564
    95
    Dec 21, 2007
    I could complain about it but having a boat is a good problem to have. 2007 indmar 5.7 hard starts cold and hot. Crank it cold several times and it usually fires up. If I run it for 20 min shut it down and start it within 5 min it will fire right back up. Let it sit for 10 min and same thing, gotta crank serveral times. Fuel pressure is good, no bleed off. What parts could be bad? At first I thought it was heat related but it will do it dead cold too. I can pretty much guarantee after running it and letting it sit for 10 min the no start will happen. Ignition control module is my first thought. crank sensor, cam sensor, what else? No lanyard, so thats not it. 800 hours, serviced every 80 hours. oil,plugs,rotor,cap,impeller,trans,v drive fluid and fuel filter. Any ideas? Control module is 180$
  2. SBMech
    SBMech Fixes Broken Stuff
    7,161
    8,915
    Jul 25, 2012
    Since it's intermittent, you can pretty much rule out mechanical issues, no spark/injection pulse could be crank sensor hot soak issue. Testing it will save you money over throwing parts at it.
  3. 4Waters
    4Waters Well-Known Member
    7,764
    13,632
    Aug 28, 2016
    Check grounds as well
  4. Shlbyntro
    Shlbyntro Well-Known Member
    1,143
    1,438
    May 27, 2018
    Some marine engine systems are wired to derive ignition source power from the alternator. If yours is one of these, it could be an intermittantly bad alternator. Next time it does it, be ready to jump power from the hot power post on the starter to the purple wire going into coil. If it starts right up, that's your issue.
    Other culprits could be your iac getting jammed, or possibly a bad map sensor as well. This is where a scan tool would be handy
    Headless hula and monkeyswrench like this.
  5. Yellowboat
    Yellowboat Well-Known Member
    15,312
    5,470
    Dec 18, 2007
    Start with your grounds and connection. Then move on too testing crank/ cam position sensors.
  6. badluck
    564
    95
    Dec 21, 2007
    iac?
  7. SBMech
    7,161
    8,915
    Jul 25, 2012
    Idle Air Control Valve
  8. SBMech
    7,161
    8,915
    Jul 25, 2012
    When it finally starts is it loaded up or does it start like nothing was wrong?
  9. badluck
    564
    95
    Dec 21, 2007
    Starts like nothing’s wrong
  10. Yellowboat
    15,312
    5,470
    Dec 18, 2007
    Normally when an iac goes bad it won't idle worth a shit. Think like a carb with a bad vaccumm leak.
  11. badluck
    564
    95
    Dec 21, 2007
    Will the iac stop spark? It does not even fart. Just turns over
  12. badluck
    564
    95
    Dec 21, 2007
    It runs great
  13. 4Waters
    7,764
    13,632
    Aug 28, 2016
    How do you know it has no spark, have you checked it or are you just thinking that's it
  14. Shlbyntro
    1,143
    1,438
    May 27, 2018
    The iac wouldnt stop spark. But I have seen them jammed wide open to where the engine wouldnt start and almost seamed like no spark until after it fired on several occasions.
    Verifying spark when this happens again would be the first step to know which route you need to go
  15. buck35
    buck35 Well-Known Member
    3,446
    2,880
    Jan 27, 2015
    A plug in spark checker is about 4 bucks at oreiillies.
  16. 4Waters
    7,764
    13,632
    Aug 28, 2016
  17. racetrash
    racetrash Well-Known Member
    200
    285
    Sep 10, 2018
    Try a diff prop??
  18. monkeyswrench
    monkeyswrench Well-Known Member
    4,194
    6,476
    Sep 7, 2018
    Shlbyntro and 4Waters like this.
  19. 4Waters
    7,764
    13,632
    Aug 28, 2016
    It's a good lesson :D
  20. Shlbyntro
    1,143
    1,438
    May 27, 2018
    I tend to forget and have to relearn this lesson at least a couple times a year. Always seams to be on outboards too :/
    4Waters likes this.
  21. badluck
    564
    95
    Dec 21, 2007
    Used a timing light to verify no spark
  22. monkeyswrench
    4,194
    6,476
    Sep 7, 2018
    Where's the fun in that?:p
    J/K...probably the best way, don't have to worry about damaging a boot either.
    4Waters likes this.
  23. Yellowboat
    15,312
    5,470
    Dec 18, 2007
    Timing lights just tell you spark is going too the plug... not that you actually have spark. When I was in my teens had a truck that we could not figure out why it ran like shit, until we pulled the plugs
  24. 4Waters
    7,764
    13,632
    Aug 28, 2016
    Try an MSD with a Pro Power coil (55,000v), after you get your breath back and get off the floor it's burned into your head. LOL :p:D But I did learn that lesson a few times before the incident:eek:
    Blue and Shlbyntro like this.
  25. badluck
    564
    95
    Dec 21, 2007
    I pulled a plug and it looks great. They have about 4 hours on them.
  26. badluck
    564
    95
    Dec 21, 2007
    How do I test the ignition control module?
  27. Headless hula
    Headless hula Well-Known Member
    8,949
    16,872
    May 24, 2016
    Sketchy ground. Corrosion, swelling paint where they are attached to the engine....
    Pull em, scrub paint and retest.
    90% of the time is a shitty ground.
    Your ad here likes this.
  28. rrrr
    rrrr Well-Known Member
    7,569
    10,620
    Dec 19, 2007
    This reminds me of my debut as a sprint car team mud scraper and gofer. The crew chief was holding a Vertex mag, and he told me to grab the wire dangling from it.
    I did, and he spun the drive gear...shocked the f*ck outta me, everyone in the pit got a good laugh.
  29. rrrr
    7,569
    10,620
    Dec 19, 2007
    It's an electronic fuel injected COP engine. :D
    Chris Lapoint likes this.
  30. Chris Lapoint
    Chris Lapoint Well-Known Member
    247
    587
    May 7, 2018
    Lol should have read everything in its entirety , I retract my trouble shooting advice.
  31. namba860
    namba860 Well-Known Member
    3,627
    2,973
    Jul 15, 2010
    Unscrew the IC module clean the screws read good and under the module and the clean out the threads where the screws go in.
  32. rrrr
    7,569
    10,620
    Dec 19, 2007
    That's OK, I almost did the same thing. :D
  33. Blue
    Blue Well-Known Member
    1,750
    2,856
    Oct 4, 2007
    Yeah those mofo's hurt. It doesn't even feel like electricity it's hard to describe
    4Waters likes this.
  34. mash on it
    mash on it Beyond Hell Crew
    1,105
    1,245
    Jan 26, 2011
    Oil pressure sending unit
    Dan'l
  35. badluck
    564
    95
    Dec 21, 2007
    Made some progress today. 3.9 volts measured at the coil with key on. If I leave the key on for 10 seconds it goes to 12 volts. Then it starts no problem. During the 10 seconds with the key in the on position I hear a whining sound. At about 10 seconds the whine stops and I get 12 volts. The other day after the whine stopped I'd hear a click click. I think its a relay failing. Any ideas? Trying to pin point the whine. It seems to be ontop of the motor under the intake manifold cover.
  36. Yellowboat
    15,312
    5,470
    Dec 18, 2007
    Fuel pump?
  37. namba860
    3,627
    2,973
    Jul 15, 2010
    I would trace down the purple ignition wire from the plus side of the coil to the relay then unplug the relay and test the purple wire from the ignition switch to the relay and see what the voltage is without the relay in the system
  38. Shlbyntro
    1,143
    1,438
    May 27, 2018
    That whine almost sounds like the fuel pump prime. Replacing the relays is cheapest but may be an electric fuel pump that isnt jammed but internally shorted. Something is definitely drawing more power than it should which is throwing your ignition out of whack with that low voltage
  39. rush1
    rush1 Well-Known Member
    2,095
    1,427
    Dec 25, 2013
    4Waters likes this.
  40. badluck
    564
    95
    Dec 21, 2007
    It seems like throttle position sensor is where the whining is coming from. When I disconnect the plug from the tps the coil reads 12 volts and there is no whine. Fuel pump prime stops way before this whine. This is a drive by wire setup. No throttle cable. So it starts up when I unplug it but dies immediately.
  41. DaveH
    DaveH Well-Known Member
    1,360
    738
    Sep 9, 2008
    im not convinced its a spark issue.
    first of all being a DBW application, there is more to the TPS then the sensor. that is a servo motor with multiple position sensors....there is no commonality in the wiring between the ignition system and the throttle. some throttle servos go through a reset process when you key on and that may be the noise you are hearing.
    it sounds to me like either a fuel pump/pressure issue. I have also seen injectors leak fuel and load up the engine. many engines hold fuel pressure even after the pump stops...to facilitate quick start up....but with a leaky injector the fuel slowly drips into a cylinder, partially flooding the engine and then with no pressure for the next start takes a couple cycles of the pump to get the pressure back up, not to mention clearing the flooded condition....in all making for a hard starting engine that runs ok once going.
    anytime you have ignition system woes....the first order of business is to simply throw a set of plugs and wires at it. I have seen many intermittent issues go away from components that looked/tested fine.
  42. badluck
    564
    95
    Dec 21, 2007
    Definitely an ignition problem. If the throttle body is disconnected 12 volts at the coil. 3.9 when it’s connected. Timing light shows no spark. Won’t start with 3.9 volts out of the coil. Starts every time when it reada12 volts. As soon as the tps stops whining the voltage goes to 12. It whines for about 6 seconds longer than the fuel pump. I definitely know the difference.
  43. Shlbyntro
    1,143
    1,438
    May 27, 2018
    I'm leaning towards a possible bad throttle plate driver motor... shorted out windings in the motor are a strong possibility
  44. badluck
    564
    95
    Dec 21, 2007
    Leaning same direction
  45. buck35
    3,446
    2,880
    Jan 27, 2015
    I have a Merc 502 and had a similar problem a couple of years ago . No start or fire and die when I tried to shift. I took off the tps and cleaned it out, it was gunked up . No problems since, and it cost nothing but an hour or two of my time.:cool:
    Good luck on your resolution.
  46. badluck
    564
    95
    Dec 21, 2007
    Tried a new throttle body tps. No luck. Same sound same voltage.
  47. buck35
    3,446
    2,880
    Jan 27, 2015
    Clean every connection you can find/ reach. Sounds like you have an electrical issue and that's not in my pay grade.
  48. Headless hula
    8,949
    16,872
    May 24, 2016
    Iac?
  49. namba860
    3,627
    2,973
    Jul 15, 2010
    I would probably start looking real hard at that ECM. You really should get it scanned instead of throwing parts at it.
    HST4ME likes this.
  50. HST4ME
    HST4ME Well-Known Member
    2,810
    4,506
    Nov 9, 2015
    Mmmm MEFI 5 FBW ... fucking pain in the ass. I'd be looking at the throttle plate driver. If you can find someone with a Rinda Techmate it should scan it.
    buck35 likes this.
Share This Page
