So I have a XR drive in my conquest deck that I'm trying to figure out the source of the oil leak. So to map it out since I don't have pics (boats in storage at the river), you have the two cables coming from the shift lever back to the transom that goes to the shift fork. From the shift fork, the arm pivots depending on if you are in forward or reverse either pushing or pulling the single cable that goes to the outdrive. Well that cable will drip drive oil on the fork side. Its a minor leak that is more of a nuisance than anything. Can someone help point to the bad seal, and is this something easily fixed?
