Original Gale Banks turbo engine rotating assembly.
obnoxious001
Engine building character
This assembly consists of a GM steel crank that is still std/std, a set of standard length Carrillo rods (6.135"), and a set of "Banks" turbo pistons in standard 4.250" bore. I will have to get to them later for photos if there is some interest, but upon my first inspection all parts appeared to be in fine condition. $1500 obo.
I believe I have a standard bore GM block if someone wanted to build an "original" Banks turbo engine, but it's early enough it has collectible value. I also have a Gale Banks turbo kit here, currently minus the Rajay turbos. Add some 990 heads and you could have one like Banks used to turn them out.
