Yes, it's called a PTO. Small bolt pattern for 1 pc, larger bolt pattern for 2 PC and big block.
If you have a Rockwell type PTO with u-joint, you'll need the companion flange 4 bolt u-joint that fits the PTO, and your u-joint size, most are 1310's, although 1350's are pretty common too.
