FOR SALE.
This boat is located in Cleveland, Ohio. Has only seen Lake Erie freshwater since complete overhaul in 2000.
-1978 32' Spectra
-Limited production boat made in southern California as an ocean runner, less than 60 were created before the molds were sold in 1982.
-Roughly 100-150 hours on complete remanufactured drivetrain (2000).
-Twin 350 mercruiser 5.7L
-Highly desirable Borg Warner Transmissions
-TRS Outdrives
-Engines, transmissions, and drives remanufactured and installed in 2000.
-Cockpit interior redone in 2000 with new drop out bolster seats.
-Triple axle trailer included with custom bunks placed for proper strap lifting. (trailer will need wiring work and probably needs tires, can work with you to get it highway ready)
Custom arch. Custom support lines up front, don't know the technical term. Custom made split engine hatches. KC Performance epoxy bottom paint. Two new (in 2000) 100 gallon gas tanks that are barrier coated and foamed in. PO replaced the rear bulkhead in front of the engines. Hynautic steering. Interior is original to my knowledge and in good shape. No mildew or mold in the cabin. Circular couch seating with long bed up front. Bilge pumps, blowers, drive trim, trim tabs, and lights all function properly. Floor, stringers, and transom all solid. bilge area is clean. 3 newer batteries. On board marine battery charger. Automatic fire suppressant system in the motor compartment. Minor spider cracks here and there but that is to be expected of a 1978 hull. Canvas moorning cover. No windshield. Transmissions shift properly and shift smooth. Props good.
Hours on hull unknown, meters show around 1100 hours but they don't work. Estimating the hull has around 1200-1300 hours.
Clean and clear title in my name. Price is 14k.
-1978 32' Spectra
-TRS Outdrives
