[SOLD] Playtech Fabrication Sandrail...
6 balls
2001 Sandrail (original owner)
Builder: Owner designed and built, chassis by Playtech Fabrication (John Gould)
Chassis: 4130 chromoly, four seater (124” wheelbase) (1350 lbs)
Front suspension: Suspensions Unlimited unequal length chromoly A-arms, spindles, 2” X 10” King dual rate coil-overs with remote reservoirs (17” of travel)
Rear suspension: IRS, 3X3 boxed dual pivot chromoly trailing arms, 2½” X 12” King dual rate coil-overs with remote reservoirs (17” of travel)
Steering: RBP Manufacturing billet rack and pinion
Transmission: 091, 4.57 ring & pinion, 3.55 1st , 2.21 2nd, 1.68 3rd, 1.25 4th. Superdiff, molly diff cover/retainer, vented & gusseted case, by Rancho Performance
Axles: Sway-away axles, race prepped 930 cv’s
Engine: 2276cc Type 1, longblock by Proformance (Dave Greiner)
128 hp with 141 lb ft of torque at the wheels, Chassis Dyno by Superior Automotive
Bugpack “Superstroke” forged 4340 chromoly crank (82mm)
Scat forged 4340 chromoly stroker I-beam rods (5.6”)
ARP 2000 rod bolts (5/16”)
Cima 94B Forged pistons & cylinders
Deves H.P. rings
Engle 125 cam (.460 lift, 301 duration)
Chromoly push rods
1.1 rockers
Stainless pushrod tubes
Welded wedgeport heads (9.2:1 compression)
Stainless steel valves (44mm intake, 37.5mm exhaust)
Copper head gaskets
Match-ported intakes
Dual 45 Dellorto DRLA's
K&N filters/Outerwears
Competition merged exhaust with supertrapp (ceramic coated)
Bosch 009 chrome distributor w/Compufire breakerless ignition
MSD 6A ignition control
Compufire coil
Bosch silicone wires
Bosch chrome alternator
Scat power pulley
Odyssey 925 battery
Scat chrome tins
Holley "Red" electronic fuel pump and regulator
Mesa 96 plate oil cooler
Remote HP1 oil filter
Stainless braided oil and fuel lines
Kennedy 1700lb pressure plate
Brakes: Jamar 4 piston billet disc brakes (rear)
Wheels: Douglas "Red Label" (.190) 5 lug 15”X12” (rear), Spindle mount 15”X4” (front)
Tires: Xtreme “Eliminator” sportsman cut 14.50” (rear), “Apex” 6.80” (front)
Seats: Beard Superseats lowback fronts w/bench rear
Restraints: Crow 3” 5-point harnesses with wrist restraints
Fuel tank: Spun aluminum (13 gal), stainless straps
Controls: Jamar billet pedals, Jamar billet turning brakes, Grant steering wheel, Class-Act billet shifter
Instruments: Polished aluminum center console, Autometer “Sport Comp” gauges (tach, oil pressure, volts)
Lighting: Lazer Star chrome “Hemi” (2) 100W floods (2) 100W spots, rigid mount “Shorty” taillights, lighted whip, LED under car lighting
Floor pans: Aluminum, by owner (.120”)
Wing trunk: Aluminum, by owner
Side panels: Aluminum, by Mac Fab (Matt Collins)
Powder Coating: Olympic Powder Coating, Santa Ana
$16,500
20' Universal enclosed trailer with 50 gallon fuel tank and pump station available.
$6000 with sandrail purchase
(Will not sell trailer separately unless car is sold first)
ONE-A-DAY
Very nice, I would say selling the 20 foot universal with fuel station for $6000 is about $4000 low
6 balls
Thank you!
I'll only sell the trailer at that price as a package with the car. Trailer only, the price will go up.
ONE-A-DAY
Thank you!
I paid $9000 for my universal 24 with fuel and water stations and that was a bro deal for a buddy.
I agree, someone might buy the package just to flip it at that price
Edit, quoted the wrong reply of yours, oh well.
6 balls
Bump for the upcoming sand season...
