rmarion
- Mar 14, 2008
- 5,826
- 9,594
You know if a pontoon Bimini rated for 100+?Weak. No Bimini.
You mean 50+You know if a pontoon Bimini rated for 100+?
Guess we'll see when you get your Toon with twin 500's!You know if a pontoon Bimini rated for 100+?
If it were rated it would be a frickin kite.You know if a pontoon Bimini rated for 100+?
How 'bout the worlds fastest 6cyl. Toyota?Worlds fastest pontoon
worlds fastest prius
worlds fastest tricycle
Seriously...... who cares. Amazingly lame.![]()
Impressive as all hell, but damnit, I want to see mph, not this BS kilometer metric stuff!Or the fastest door slammer ?
Or this run from a couple of hours ago.Worlds fastest pontoon
Put a cork in it Grads.I'd be more impressed if said 100 m.p.h. pontoon was grilling burgers and wieners at the same time.
Did you notice the name on the side window? Can't be him, but is it a dedication to Khalid Mohammed? Or is that just a common name?Or the fastest door slammer ?
It's right in the title, 277.99 MPH.Impressive as all hell, but damnit, I want to see mph, not this BS kilometer metric stuff!
Only on Craigslist...I hear they're faster on Facebook thoughA little lame when the worlds slowest jet boat tops 100 mph easily
fuck yes!
Looks like perfect weather for record runs, 73Β°F during yesterday's run was 10-15 degrees cooler than average.
They are currently running a 555ci. BBC. I'm not sure if they are going after another two class records this week or not.Looks like perfect weather for record runs, 73Β°F during yesterday's run was 10-15 degrees cooler than average.
They're running a +501 cubic inch engine and going after the AA/BFS record. The engine can produce more than 3,000 HP, but it's dialed back. Otherwise the engine would produce wheelspin in all gears, killing the speed.
They had a real challenge fitting the Gen VI big block between the frame rails. Judging from the time slips it looks like they're coming home with the record.
You're back from the dead???I'd be more impressed if said 100 m.p.h. pontoon was grilling burgers and wieners at the same time.
Right. I said '501+ cubic inches', because that's the step from A/BFS to AA/BFS. I also noted it was a Gen VI big block.They are currently running a 555ci. BBC. I'm not sure if they are going after another two class records this week or not.
Yes, I did understand your +501 and was only offering usless information that only you and I might appriciate and in no way meant it as a correction to your post.Right. I said '501+ cubic inches', because that's the step from A/BFS to AA/BFS. I also noted it was a Gen VI big block.
With the larger engine and the fact it has forced air induction, the only other class record they can grab is by switching to gas and running in AA/BGS. If they have another engine prepped that's under 500 CI, they can go after the A/BFS and A/BGS record. I don't recall if the Speed Demon currently holds those records, but even if it does they can attempt to reset them.
Thing drifted like a kite!Fastest flying Lexus
And I'll make more useless comments about your useless comments. It should also be noted we're threadcrapping in a thread about ridiculously overpowered and overpriced pontoon boats, which neither of us own.Yes, I did understand your +501 and was only offering usless information that only you and I might appriciate and in no way meant it as a correction to your post.
As more useless info. comes in I'll update this thread if deemed useless enough.![]()
This thread was DOA until we came along. RD should be paying us!And I'll make more useless comments about your useless comments. It should also be noted we're threadcrapping in a thread about ridiculously overpowered and overpriced pontoon boats, which neither of us own.
This should result in a two week ban for both of us, because we have no business being here, are obviously uncool, and just a couple of old dinosaurs.
They are getting ready to run again this morning. Shane said yesterday they found an issue that should be good for a little more.They are currently running a 555ci. BBC. I'm not sure if they are going after another two class records this week or not.
From who's sending me the time slips I'm guessing Shane Tecklenburg is tuning the engine.
@parker ed should know more about their intentions for the week
NOW that your done proving some point......Right. I said '501+ cubic inches', because that's the step from A/BFS to AA/BFS. I also noted it was a Gen VI big block.
Are there any live videos being shot and broadcast over the net? The only info. I'm getting are the time slips from Tek after the run.They are getting ready to run again this morning. Shane said yesterday they found an issue that should be good for a little more.
Now you're catching on. Seize the moment and make this thread your own.NOW that your done proving some point......
Back to Lame 100mph beer cans.
Seems like 60mph, big cooler, BBQ is more in line with toon bragging![]()
I'm told that the 257 ci engine is going in now.Right. I said '501+ cubic inches', because that's the step from A/BFS to AA/BFS. I also noted it was a Gen VI big block.
And if you don't believe it, just look at Stevens good morning Parker thread.![]()
Diversity, it's a way of life on RDP.I just find it funny that I keep looking at a thread on pontoon boats, on a boating site, to get updates on land speed record attempts![]()
Thanks Eddie!They just went 481 mph, the fastest for a piston powered vehicle.
Thought you might enjoy this useless photo.This should result in a two week ban for both of us, because we have no business being here, are obviously uncool, and just a couple of old dinosaurs.
