SchiadaJohn
- May 10, 2009
- 79
- 18
Just purchased and moved into new/resale home (new to us), 3 weeks ago. Has nice Gunite/Saltwater pool.
Previous owner left me a mess on bottom of pool, as a requirement for closing pool was to be opened and running. Owner did get running and based on first water analysis made a half-a$$ed attempt at getting chemicals balanced. Its now good as of last weekend check and water finally cleared so I could see the all the crap on the deep end bottom.
The pool has a water fall, three inlets - deep end, shallow end, and inlet on bottom. Deep end (10') is a mess with leaves, dirt, and a several leave behind diving toys on bottom. Challenge I am facing is the pump is not moving enough water to generate enough suction to vacuum bottom? Filter has four paper cartridge filters in it. Have cleaned filters 3 times including today at car wash (water only no soap). Pool is approx. 7 years old and I would imagine if there were restrictions (in plumbing) that issue would have surfaced long ago and fixed.
I replaced filters (after car wash cleaning) and immediately had 8 psi pressure in pump and what appeared to good water flow through water fall and water outlets. I am thinking success but within hour filter pressure has increased to 25-26 and flow out water falls has decreased to a trickle.
Pump/Motor is a Pentair Single Speed 1.5 HP and appears to be wired 230v single phase.
Questions:
1. Can the motor be losing power after warming up and causing loss of water flow? Is this possibly a known issue with the Pentairs?
2. I keep getting a lot of crap in filters, suggestions on how to work around clogging the filters until I can vacuum the crap off the bottom of the pool? I can dip some of the stuff off bottom but will need to vacuum off the dirt and dead algae.
Thoughts or suggestions? Its a PITA because the pump doesn't move enough water to keep the algae from returning.
Pool Specs:
Approx. 13-15K gallons.
Its a diving pool with 10' deep end and shallow end after steps is 4-1/2" or so.
I can control the inlet/outlet water flow with install valves. Currently using the settings that were on pump.
Pool was constructed by 1 of the 2 high end builders so I am making an assumption all equipment/plumbing is sized appropriately.
Questions:
Pool Specs:
