badluck
- Dec 21, 2007
- 994
- 720
How do you keep the new skimmer from leaking where it meets the bond beam?
Pool plaster is what we use to seal the joint.When the new skimmer box is put in place and you epoxy rebar in the bond beam of pool to hold it in there is there any substance between the front of the skimmer and pool. Looks like some white material in your picture.
. As I stated above we use plaster, usually try and leave about 3/4” between the pool wall and the new skimmer as you are mixing the bags of concrete fill the hole to the bottom of the skimmer throat then wet one of the concrete bags and roll it up tight slide it under the skimmer half way then fold it up one side do the same on the other finish filling the hole to the height you need, as the concrete starts to set pull the bags out that will leave you with about an inch and a half void on the bottom and sides of the skimmer, mix up a hot batch of plaster and pack it in this void and then tile over to finish. We do about 3 skimmers a week around Orange County.I’m thinking I could tackle it. My concern is where the pvc/abs skimmer meets the pool is like a cold joint. What seals the 2 together? The tile butts into the skimmer. Seems like that would be a leak
