Pork Loin
was thatguy
living in a cage of fear
24 oz. small loin for 2 people or so.
Rinse and pull loose fat from loin.
Rub with olive oil.
Little bit Cajun, little bit Johnny salt, little bit Pork rub.
Wrap in bacon, wrap in saran wrap, back in the fridge for at least 4 hours.
This will be smoked for 2 hours on traeger smoke setting, then raised to 400* until IT of 155, if needed.
was thatguy
OK, almost 5 hours in the fridge!
Removed from fridge, remove saran wrap, dust with rub and cajun on top, THEN slather with honey! (Use a little basting brush.)
In Traeger on Smoke.
Note that I have a tin of Apple Juice on the grill, and also a sprayer with Apple Juice. (Probably spray once every 30-45 minutes or so)
I also put down a foil pie pan with a small grill on top to catch drip for gravy or glaze. Plus it keeps the drain pan cleaner!
was thatguy
2 Hours on smoke, only 117 IT.
Time to jack it to Hi and monitor IT to 155!
Shouldn't take more than 20- 30 minutes tops.
was thatguy
Turned it all the way up, sprayed again with Apple juice, 25 minutes later we were at 155* internal.
Perfect smoke ring for a small loin!
Sliced about 1/2" thick, juice squirted out as it was sliced.
Plated!!:D:D:D
It was so tender it EASILY cut with a fork. (Brown could have sliced it with his plastic spork with ease)
Probably the juiciest tenderloin I've ever cooked.
Flavor was off the hook!
There is a constant debate on the grilling forums about pork loins.
Some say slow and flavor...some say fast and juicy.
I've done both and have found the TRUTH is...a little of both WITH the proper preparation.
This loin was less than 2 pounds, and ended up a absolute bounty of flavor, juiciness, and tender.
The trick is the olive oil base, the light mix of simple spices and rub, the bacon wrap, and the single slather of Honey.
Slow cook/ smoke at 200* +- until 115 - 120 IT, THEN 400* and watch the IT. Pull it at 155* IT.
This works on any size tenderloin.
Enjoy!!
