TCHB
- Jan 24, 2008
- 11,096
- 8,008
Put s
During the last RFP process the interconnections are critical and that is reason we built 1500MWs on existing plant sites.Utlitity scale Solar is more difficult than you think in Ca.
A key problem in most areas, is there is not capacity on the existing Transmission Power Line Infrastrure to support more Solar Supply.
To fully understand this problem, you have to look at the “interconnection studies” to see why its so expensive to add new facility’s/supply to the grid. Bottom line.. in most areas in Ca, you ahve to “upgrade the transmission grid” to support the added capacity, Which can cost 10-100X the cost of the Solar Plant you trying to develop.
Then compound that problem by 1000, because the Utility’s are constantly getting interconnction requests daily. Most Planning for the potential new interconnections is extremely difficult, takes a very long time, and is truly very expensive.
I am all for Nuke Power… we should should have 6 under construction in CA alone right now. That opinion is just a “national security” opinion.
