Sleek-Jet
- Sep 20, 2007
- 12,770
- 15,492
Glad to see an update, I was worried that Hulla and Hydro had inadvertently resined themselves to the hull and needed rescued!
On the center pod, it will act like a rail at lower speeds, correct? So, the center pod needs to be centered, and parallel it's entire length...How do you check the profile or cross section to keep it symmetrical?
What is the deal with your shop - is that in a personal hobby shop community? Or is that a commercial industrial park? Cool concept if it is all for personal hobby use/storage.
Dont want to hijack, but seems my 21 Liberator bottom is lacking the lifting strakes(or would that be considered a spray rail?) on the sponsons that your Daytona has...interesting.View attachment 924641
Here is my 21 Daytona with twin outboards. This off season I am having the engines pulled and the bottom cleaned up, regelled, and sharpened/blueprinted as you can see it is beat up a little. I am also taking the pitot tube off. Interesting to see the differences in bottoms. When I had the bottom of my HTM sharpened-blueprinted, I gained 3mph on the big end which I thought was pretty neat.
Dont want to hijack, but seems my 21 Liberator bottom is lacking the lifting strakes(or would that be considered a spray rail?) on the sponsons that your Daytona has...interesting. View attachment 924722 View attachment 924723
2.125". Well within Merc limits as Im told by Merc themselves. Still have TONS of water pressure at neutral trim.Also not to jack, but SOB that prop shaft is way above the bottom! What is that, 2, 2.25, maybe 2.5 inches above?
That is interesting, as it looks like our centerpods are identical though. Are your trim tabs set in position, or do you manually adjust them? Also, I have heard the Liberators like yours are a splash of the original 21' Daytona?? Is that true?Dont want to hijack, but seems my 21 Liberator bottom is lacking the lifting strakes(or would that be considered a spray rail?) on the sponsons that your Daytona has...interesting. View attachment 924722 View attachment 924723
I was under the impression they were a splash, yes. Those tabs are electric and wired to move together with a single button. They work well to add compression to the tunnels to get rid of the hop this has right between 70-80. Under normal conditions and load usually in the boat it accelerates through that range quick enough that I dont notice it. I honestly hardly ever use them.That is interesting, as it looks like our centerpods are identical though. Are your trim tabs set in position, or do you manually adjust them? Also, I have heard the Liberators like yours are a splash of the original 21' Daytona?? Is that true?
Really? That is interesting and kind of neat actually. Not many 21's were rigged with twins, I have heard 6-8. Some went back to singles, some blew over, and at least one went to the this strange OCD guy typing.This is the first 21 Daytona I’ve seen with spray rails. They’re not huge, but they’re there.
This usually helps keep the boat flat while cornering instead of leaning out at medium to lower speeds.
Is this the case with this hull?
Do you drop them to get on plane? I get a decent amount (not crazy) of bow lift coming on plane, it then hops twice and that's it. I don't get any hop up to and past 100.I was under the impression they were a splash, yes. Those tabs are electric and wired to move together with a single button. They work well to add compression to the tunnels to get rid of the hop this has right between 70-80. Under normal conditions and load usually in the boat it accelerates through that range quick enough that I dont notice it. I honestly hardly ever use them.
Have you spoken about or touched on the subject of a notch on the rear of some hulls? I know some builders simply have a plug they install when laying up a hull so it is notched or not?All pod and hull discussion is welcome here.
The spray rails add running surface, lift, and water deflection, more so in turns. The running surface aids in planing and acceleration. I don’t know of a defined minimum width, but I do know I’ve never seen a race boat or fast production boat with less than 2” width.
I made mine 2” wide, similar to 340X MTI.
What are they for and why did you not go with one?
Notches generally are like adding more setback, and you generally see them more on West Coast sterndrive boats. At least that’s generally more what they’re geared towards.
You’ll see that the faster OB cats don’t have notches, or very small ones. It affects Longitudinal CG by moving the edge of the running surface (fulcrum of the teeter-totter).
You’ll also see that those hulls with the filled notches, spray rails, and we’ll-placed strakes also plane effortlessly.
I see, I see...yes, my HTM had them, but so did my Spectre (36) and so did my Skater (40)Notches generally are like adding more setback, and you generally see them more on West Coast sterndrive boats. At least that’s generally more what they’re geared towards.
I would love to come run the Wolf River with you next year.
I'm not posting for anyone's benefit other than whoever can learn something from this thread.
I focused on getting the details taken care of on the pod splice at the front. The original pod wasn’t exactly centered, and my new one is, so I had to shift the keel over about 3/16”. Medium Wally was up to the task.
I’m really pleased with the results, it’ll look great once gelcoated.
Sanded out the port sponson vertical surfaces, as well as the radii at the top and bottom of the spray rails. I’m pleased with how they turned out as well.
There were some low spots, so I prepped and filled them last thing before I left tonight.
I brought some supervision with the last three days. Unfortunately the mutt has had a tough week and is having stomach problems. He chilled and got some of his appetite back.
It’s funny how all the noise doesn’t phase him in the least.
Tomorrow I’ll finish out the touch-ups, and get after flattening the starboard sponson vertical surfaces.
That’s crazy and so much work, looks slightly to be the port side right? That’s just for your own ocd as the nose shouldn’t ever really see water, but at this point yes you’ve gone to all the way and she’s going going to be amazing.
They were on the boat when I bought it. Randy puts them on pretty much all the Liberators he rigs. 12x12 Lenco electric. It is nice to be able to shut down any hop if thats where you want to cruise.Did you add the tabs or were they added prior to you? Looking to do a set of the new MIW either fixed or hydraulic tabs on my F26 as she’s got a little hippety hop and well it’s from 62-70 and well that’s a good cruise speed for us we are being robbed of. So curious what exactly you’ve gained from the tabs.
I can't be the only one that checks this thread daily for updates... I feel like we are overdue. Can't wait to see the next update. Keep up the profound work.
Sorry guys. Sick dog, false COVID scare, and my favorite aunt passed this week kind of shot any attention that I would have spent on the StressEliminator right in the ass.
I’ll be back on it shortly. There’s just other stuff more important right now. I’ve literally missed less than 10 days since May 31 other than work travel or family/guest activities.
HulaHut is about 50 minutes from my house, so it’s really been like a second job. I’m truly looking forward to getting this done and running yet this year before the water gets hard.
Thanks for following, fellas, and I’ll update it soon.
Looking good! You guys sure are becoming a fiberglass fab shop, I hope to get mine finally on the water next spring, maybe if I get it dialed in I’ll have to come run the wolf!
Hopefully your remodel is about wrapped up and you can get back on it.
If you decide to run from Oshkosh to New London with us, that’s about 100 mile round trip. Hula and I might need to carry fuel for you! We could probably just start out with a trip to Fremont. Hula has done Winneconne to Fremont in 11 minutes during the week when there’s not any no wake zones, skiers, tubers, or fishermen parked crossways in the middle of the river
