Prop Guru question
EBT531
I have a 29' Lavey with a 500efi and IMCO SCX extreme outdrive. Current prop is a Bravo I 26P but the motor will only pull it to 4800rpm's. I had the prop checked and its in spec at 26P with no damage or changes. The motor was checked out as well and has no issues other than the gas is from Sept which I am trying to run down but there was 150 gallons of it. If I over trim, the motor pulls past 5k if that means anything.
I know this outdrive has higher slip numbers (I'm at about 20% now), so is the best route to have the 26 labbed for the extra 300rpm? OR switch to a 5 blade etc. that might help reduce the slip?
I have a 24P bravo I that I can try but I like the cruise speeds of the 26P and figure the 26P will be faster if I can get the extra 300rpm's from labbing.
Last question would be who is the go to for Labbing these days?
I ran a brand new 26 B1 and similar rpms. With my labbed 26 from Hill I can hit rev limiter with 2 people low fuel. I run a 24 or 23 rev for tubing. Need to buy a 25 which is best for all around with my setup.
EBT531
How much speed did you pick up with the Labbed version? Any side effects you don't like?
2 mph or so on speedo not GPS. Only ran it wide open a few times since. Happy with it. I bought and sold a half dozen props for this boat kept the 3 best need to buy a 25p from Jacos but prop shopping for a different boat currently.
bocco
I am shopping props also. Big price difference between Hill Marine and BBlades. Are BBlades that much better?
Rbcconst
If you could get your hands on a 24p 5blade i think youll be pleased. The max5 would be your best but the cutting edge would also do. No smaller then 15 1/4 diameter.
