King295
Well-Known Inmate #20225
- Aug 8, 2017
- 1,826
- 2,757
Looking to RDP for some help. Before we dive into things, let's start with the back story(ies) that led me to needing some help.
Incident #1 - Seadoo cuts me off going through a narrow stretch of the lower river where I was running in the deep line. I had to cut to avoid hitting said seadoo and crossed out of the deep line and my prop hit a sand / soft rock bar. Didn't feel the hit very much but heard it loud and clear and kept rolling back to my place. Noticed a slight vibration upon acceleration when I was headed for the launch after dropping everyone off. I decided the prop wasn't worth sending out for repair as it was the original prop (2004) and was an OJ as opposed to the newer Acme props which are CNC'd. All prop blades blades had some fair size knicks / bends.
Response to Incident #1 - Bought a new ACME prop.
Incident #2 - First day with new prop, headed up from Havasu to Topock last month to run the new prop. Had some lunch and headed back down river. Between the gorge and the mouth of the river there was a mass group of kayaks and canoes on the AZ side and a boat was coming up river giving them room. I was hugging the AZ side on my way down since I knew there was a sand bar on the CA side but I underestimated how far out it came (about 1/2 way as it turns out) and I hit the sand bar at about 20-25 mph. The boat drug about 25' feet and came to a stop. A kind group of fishermen and a pontoon helped out and we got it off the sandbar and I limped back to the marina with a severely bruised ego and another damaged prop.
Response to Incident #2 - I sent the new, newly damaged, prop to have it repaired and here was the result:
While the repairs are being done I figured what the hell, I'm going to grab another new prop and use the repaired ACME prop as a spare. Due to hitting rather hard (stopping me in my tracks) in Incident #2 my prop repair shop recommended that I check my prop shaft to ensure I did not damage it. Now I should preface I am by no means a mechanic so I called up my buddy that is a mechanic and he let me borrow his dial indicator with magnetic base. I took two different measurement points. They yielded rather quite different results which is why I'm looking for help/advice here.
Video #1
Here I put the dial indicator just before the prop shaft strut. I noticed there is some play in the cutlass bearing. As far as I am aware this is the original cutlass bearing which is on a 2004 Supra Launch with 700 hours. You can see the dial indicator move pretty drastically when I turn the prop shaft by hand. At the end of this video I push on it from left to right to show the movement.
Here is how I setup the dial indicator for video #1:
Here is video #1:
Here is a picture of the cutlass bearing:
Video #2
Here I put the dial indicator about mid way between the strut and where the prop shaft comes out of the hull. This yielded a much more significant runout than my first video which has me concerned.
Here is how I setup the dial indicator for video #2:
Here is video #2:
What do you guys think based on the above? Am I completely screwing this up and not getting an accurate runout reading? Once again, not a mechanic whatsoever, but I'm out in Parker for the weekend to toy with this and drag it home if necessary. I brought the new prop with me and was thinking I'd toss it on and go test it to see if I have any vibrations. Bad idea?
Any input/advice is greatly appreciated.
Video #1
Here is video #1:
Video #2
Here is video #2:
