Building a 505 mark IV BBC. Long story short, the original machinist botched an .080 bore on the BBC and now I'm sitting at .100 over. New machine shop says it's good to go but obviously needs new pistons. If I'm buying new pistons I might as well stroke it and get all I can out of it. Stroker kit only comes with 20 cc dome forged pistons so I'm looking at 12.4:1 or 10.5:1 compression depending on which heads I use. The small chamber heads are matched to the cam and freshly rebuilt. Comp cams says I should be in the 600s for HP regardless of heads and that means it won't spin past 6000 rpm (if my pump is tight). Less compression means less HP but should I push the block at .100 over and go with the higher compression or even forced breathing? E85 is plentiful here in corn country but I'd prefer to run a pump gas motor. I'm thinking studs all around and see what she'll do. Cam is a hydraulic roller lifter cam from Comp. With all the aftermarket blocks people rarely run .100 over on a stock block any more, so I'm looking for guidance from those that have been there.
