I was riding it and it just died I tried starting it but it just keeps cranking over like it’s out of gas which it isn’t. Next trip to the river I’ll check the compression on each cylinder and see it that tells me anything. I’m open for suggestions or who could look at it and maybe fix it if needed in the Parker/ Lake Havasu Area.I may be able to help, what do you have going on?
Compression is definitely the first place to start, just because there is fuel in the tank doesn’t mean there is fuel in the carbs. If you have compression and spark then hit it with some starting fluid to see if it pops over.
Sent you a messageThanks I’ll try that and if no luck I’ll bring it over for you to look at. Send me the link of you web page and I’ll contact you next time I’m coming out and setup an appointment.
Thanks: Tab
