Radius Arms - Canned Ham
Discussion in 'RD's Lounge' started by RiverDave, Nov 22, 2019.
  1. hallett21
    hallett21 Well-Known Member
    7,578
    3,802
    Nov 9, 2010
    Alright I wanna know about the prop you’re machining
  2. DLC
    DLC Well-Known Member
    2,664
    2,325
    Jan 18, 2013
    yes sir! 50mph on the trailer up the 15 north, sometimes faster headed home ....
    lol
    Waffles and rrrr like this.
  3. RiverDave
    RiverDave In it to win it
    95,588
    62,541
    Sep 13, 2007
    These things take some of the sport out of it.. lol.
    Way faster thank I’ll ever need to go in the desert.
    97025017-F360-4A4D-ABC3-5B67C7B07F42.jpeg 50316721-F86F-4533-BEDF-F7FB216988DB.jpeg
  4. DLC
    2,664
    2,325
    Jan 18, 2013
    Looks great with some dirt on it!
    cheers!
  5. 02HoWaRd26
    02HoWaRd26 Well-Known Member
    4,282
    4,642
    Dec 19, 2007
    Try aiming the fronts out about a total of 1/2” before your next decent distance dirt ride. Car will turn twice as hard and track straighter everywhere else.
    LargeOrangeFont likes this.
  6. rivermobster
    rivermobster Club Banned
    35,415
    14,047
    Dec 28, 2009
    Yep. Much better!
  7. Happy Smitty
    Happy Smitty Active Member
    34
    78
    Nov 9, 2019
    With the stronger radius rods you need to keep a few extra center rod knuckle bolts. Now that your center rod wont fail the bolt is next in line to fail. Seems to happen to someone when I'm riding with a group of 40 cars on the annual winter and spring runs. Screenshot_20191122-185032_Chrome.jpg
  8. brianwhiteboy
    brianwhiteboy Professional Lurker
    888
    1,827
    Dec 20, 2007
    107 responses on how to tighten a SxS nut. It must be winter. :cool:
  9. LargeOrangeFont
    LargeOrangeFont Steers With Throttle
    19,332
    22,731
    Sep 4, 2015
    Yea that will rip in the dirt.. those tires will be howling on the street though :). I have about 1/4” toe out up front on my RZR now, which is quite a bit more than stock.
  10. LargeOrangeFont
    19,332
    22,731
    Sep 4, 2015
  11. LargeOrangeFont
    19,332
    22,731
    Sep 4, 2015
    Can it be replaced with an ARP bolt or something? Or will the hub break then?
    Oh those Canned Hams :).
  12. Waffles
    Waffles Well-Known Member
    3,988
    5,401
    Jul 12, 2012
    Shocking but yes. Clocked it going 56 a couple of times on GPS on the stoddard Wells and rasor rd's main road. I dumped a ton of fucking money into that thing to make it what it was
  13. 02HoWaRd26
    4,282
    4,642
    Dec 19, 2007
    Well i use 1/2” but I’m also 91” wide on 35’s. But yea once you go toe out it’s hard to toe in ever again.
  14. LargeOrangeFont
    19,332
    22,731
    Sep 4, 2015
    In my fleet, if it has solid arm bushings, it gets toad out in front :)
  15. LargeOrangeFont
    19,332
    22,731
    Sep 4, 2015
    Mine hit like 48 GPS on flat ground. Stock motor and exhaust. It felt like I was doing 100 lol.
  16. Icky
    Icky Well-Known Member
    4,349
    4,198
    Jan 11, 2015
    I always heard toe in up front tracks straighter, not as twitchy on the steering. Toe out the opposite
  17. 02HoWaRd26
    4,282
    4,642
    Dec 19, 2007
    Asphalt vs Dirt.
    Icky likes this.
  18. LargeOrangeFont
    19,332
    22,731
    Sep 4, 2015
    It will track straight with either toe in or out. Toe out is more aggressive on initial turn in.
    If you have a stock vehicle with compliant bushings the car will gain toe out under braking, which can make the car feel unsettled or twitchy. This is why most cars are set up with slight toe in.
    Carlson-jet and Icky like this.
  19. LargeOrangeFont
    19,332
    22,731
    Sep 4, 2015
    Same rules apply, just in less quantity. 1/16”- 1/8” toe out on a sports car feels amazing.
    I run 1/16” toe out in the front of my Mazda and 3/16” rear toe in.
  20. Waffles
    3,988
    5,401
    Jul 12, 2012
    I could never get it up to speed on pavement. It always felt like it was struggling to cycle the belt through the sheave. That little bit of give I'd get from the silt on hard pack made a night and day difference.
    I had a new wet clutch slugged and installed. Machined Hunterworks sheave shimmed with 15g rollers... Purple secondary on slippery washers. Dynatek cdi, alba exhaust, rejetted......... I did everything short of throwing a big bore on it lol
    And yes it was terrifying. It didn't help that I had quarter doors so it always felt like I was going to fly out
  21. LargeOrangeFont
    19,332
    22,731
    Sep 4, 2015
    I had the hunterworks sheave setup same as you, stock wet clutch not slugged, Dynatek CDI, intake, and jetted carb. I had narrow 9 inch tires and wheels all around which helped a lot. I never did a top end run in the dirt, but it would do 40 easily.
  22. RiverDave
    95,588
    62,541
    Sep 13, 2007
    LMAO! Yes!!
    But even though I’m crippled I’m getting better! So expect a lot of boat and offroad content this winter!
    Fired up my lathe for the first time in about 8 months.
    TPC, DrunkenSailor, Gramps and 3 others like this.
  23. hallett21
    7,578
    3,802
    Nov 9, 2010
    So what’s the story on the prop?
    JayBreww likes this.
  24. LargeOrangeFont
    19,332
    22,731
    Sep 4, 2015
    Cutting off the diffuser ring it looks like.
    That’s a little nerve-wracking firing up the lathe with a prop chucked up in it lol.
    TPC and hallett21 like this.
  25. Carlson-jet
    Carlson-jet Well-Known Member
    5,550
    4,325
    Dec 19, 2007
    Of all the times one might not want to get tangled up in the lathe..:eek:
    Glad you are getting out in the shop a little. It really is good therapy. :cool:
    [​IMG]
    rrrr likes this.
  26. gqchris
    gqchris Well-Known Member
    3,912
    2,454
    Mar 24, 2008
    My best was 53mph. Lol. That was ALL in!
    TPC and LargeOrangeFont like this.
  27. Carlson-jet
    5,550
    4,325
    Dec 19, 2007
    I guess the wrench will come in 2 weeks? :p
    Can I ask what you were doing there Dave?
    Using the cuttoff?
    TPC likes this.
  28. TPC
    TPC Wrenching Dad
    24,973
    11,936
    Sep 20, 2007
    RD has out river’d the River.
    Question: RD how old are you?
    Answer: Yes.
  29. TPC
    TPC Wrenching Dad
    24,973
    11,936
    Sep 20, 2007
    7146A5A1-5B43-48BF-BF98-D2D071724BF2.jpeg E58DFD9F-2860-4D2A-9285-AF8DE35A8896.jpeg
    I walked into Kolbe Cycles sales when the Rhino first appeared on the showroom floor.
    About the same time the YFZ 450 hit.
    I bought a couple of YFZs and my GF at the time said the Rhino will be a big hit.
    I though it was a hunters vehicle and didn’t see it coming.
    Then, we were having a drink at the Glamis Beach bar and a couple drove up in a Rzr 800.
    “We sold our Raptors after our last trip with the Rzr we like it so much better” they told us.
    So, that week I bought a 800 and had 5” outside offset beadlocker wheels spun.
    [​IMG]
    They ran really good for a 800. I let all the guys in our dune group drive it all they wanted.
    Was almost the only guy at DUMONT with a Rzr for awhile. Certainly with offset beadlockers and paddle tires.
    SXSs have been a great addition to the world of off-roading.
    The popularity has for sure helped in efforts to keep riding areas open. More support. Way more participation.
    I was drinking late last night with Neil, the owner of the Joint in Randsberg.
    “SXSs have really increased interest in off roading.
    We rarely had girls in here but now women are 25% of our business” Neil told us.
    It’s the only bar my wife likes to go to.
    BTW never take women in there the Friday after Thanksgiving. 3 bouncers working and they have their hands full. Good chance fists will fly.
    Neil and Hollie actively attempting to buy the Whitehouse. The old buzzard owner will sell the business only with 1 year lease on the dirt it sits on.
    Grandfathering in health code requirements expired a few years back.
    Neil showed us the math and only an idiot would take that deal.
    RVRKID, rrrr and Ballsdeep like this.
  30. Headless hula
    Headless hula Well-Known Member
    10,242
    19,940
    May 24, 2016
    I'm in the "fine tuning" stages of getting my boat squared away. Dave did me a solid and trimmed an inch off the prop tube.
    I'm going to go run it after breakfast.
    Joker and chvynhra like this.
  31. Headless hula
    10,242
    19,940
    May 24, 2016
  32. LargeOrangeFont
    19,332
    22,731
    Sep 4, 2015
    Headless hula likes this.
  33. Outdrive1
    Outdrive1 Well-Known Member
    27,058
    13,376
    Dec 19, 2007
  34. rivermobster
    35,415
    14,047
    Dec 28, 2009
    RVRKID likes this.
  35. Universal Elements
    Universal Elements Well-Known Member
    2,990
    5,189
    Dec 19, 2007
    Do you leave the edges the way they are? Or do you round or polish them?
  36. Headless hula
    10,242
    19,940
    May 24, 2016
    Dave just hit it with a file. Just break the burr.
  37. Universal Elements
    2,990
    5,189
    Dec 19, 2007
    oh I see
  38. Go-Fly
    Go-Fly Where Are My Shoes?
    4,205
    4,429
    Mar 2, 2010
  39. buck35
    buck35 Well-Known Member
    3,948
    3,360
    Jan 27, 2015
    And the results are?
    Years ago my buddy shaved his beard off one day and his little girl asked him to shave it back on .:D I always think of that when trimming things .:cool::)
    RichL and Carlson-jet like this.
  40. Headless hula
    10,242
    19,940
    May 24, 2016
    It's a whole different animal. Boat ran 82 with 3 guys and ~30 gallons of gas.
    Handled fine, however it seems to have developed a very small midrange porpoise that wasnt there before.
    I'm going to run it again in the morning alone, and see if it's still there, or if the additional weight was causing it.
    C08H18, redone76 and DWC like this.
  41. C08H18
    C08H18 Well-Known Member
    191
    203
    Aug 1, 2018
    What was you baseline- speed/weight
    I’ve been told the mod will lift the ass of the boat. That may create some porpoising. I’m going to try it soon - same prop, 30p
  42. Headless hula
    10,242
    19,940
    May 24, 2016
    A long tube will actually provide stern lift in a surfacing application. Its essentially another running surface that is "riding" on the water. A long tube will also act as a "wheelie bar", limiting how much trim can be put into the boat. In my specific application, I'm trying to accomplish 2 things. Lose the drag from the extra length of the tube, and allow the boat to carry the bow a tiny bit higher, (also reducing drag, by having less boat in the water)...
    I am so close to having this setup perfect, I'm afraid that this one little change may have been too drastic. I'll go run it again in the morning and see what's up. I may wind up welding it back on, and only trimming 5/8" off it. Time will tell. :D
    rivermobster, C08H18 and JayBreww like this.
  43. Headless hula
    10,242
    19,940
    May 24, 2016
    In this pic, I'm trimmed up just a tick above neutral trim. When I set up the simrad, I was able to "calibrate" to my desired settings. Using a straight edge, projecting a line from the boat bottom to the cav plate, theres approximately 3/8" of difference front to back. I have this set as my "zero" point. I always know exactly where my trim is at at a glance. The rest is "ass-o-graph".... you can see where the spray is coming off the boat, and you can actually feel it "free up".
  44. Carlson-jet
    5,550
    4,325
    Dec 19, 2007
    So did you make the wrench Dave?
    LOL.. Hula getting all technical and shit. ^^^^
    :D:cool:
  45. C08H18
    191
    203
    Aug 1, 2018
    The spray off the step looks pretty good in that pic.
    I need to do the same straight edge calibration. Maybe tomorrow. My boat is up in NorCal (delta). I run 1/4trim up for best overall performance right now which is likely the same as your neutral. I can trim up further without much affect on bow rise and definitely slows me down.
  46. Headless hula
    10,242
    19,940
    May 24, 2016
    Boat runs just fine with the mod. It was a combination of small reflected waves, and having the weight of two not exactly small guys riding on the port side.
    It wont get any further changes. :cool:
  47. Headless hula
    10,242
    19,940
    May 24, 2016
    redone76 likes this.
Share This Page
