Bigbore500r
- Apr 28, 2014
- 17,450
- 35,461
We got a sewer camera inspection (main line) for our new house in escrow, and it had 2 issues:
One-way flap valve is stuck in open posiiton (located 19' from cleanout)
Main line has an "offset" where the ABS connects to clay (located 63' from cleanout).
The home is located on a slight hill, so some of the city sewer is located above the level of the home as the street continues uphill. Is the one-way valve a big deal? Seems like it would be needed should the sewer down-stream backup and water would attempt to backfill into the houses as the city sewer levels rise. That would be an absolute shit-storm, but seems unlikely - we are talking about the entire city sewer line becoming obstructed downstream and attempting to flood all the houses.
The main line is ABS, not sure if replaced or original. Home was built in '76. ABS line is in good shape, but has an issue where it connects to clay (assuming this is the city section? ) at 63' from cleanout. The inspector says the camera shows an offset in the connection. To me, it looks like the Clay pipe is thicker, and you can see the rim where the thicker pipe has a smaller ID. I could be wrong....i'm not a plumber. The other issue, is there are some roots at this location, i'm assuming the connection seeps a bit and roots have found the water. How is this connection typically made from ABS to Clay? Rubber boot? Those can be hydrojetted but its probably a future maintanance issue
How concerned should I be, do I need to ask for a main line repair for these items? I don't want to blow escrow up (market is hot, they may refuse to fix) but I also dont want to get stuck with 5k of main line and concrete repair. The main line doesnt have standing water or any other issues (except at connection to street) and there are no issues with how it functions currently.
What say ye?
