What all is involved in releasing a prop shaft from a casale drive ?
Feb 21, 2011 #1 F farmo83 Well-Known Member Joined Jun 9, 2008 Messages 2,405 Reaction score 2,537 What all is involved in releasing a prop shaft from a casale drive ?
Feb 22, 2011 #2 Sharp Shooter The "anti-yuppie" Joined Oct 4, 2007 Messages 7,300 Reaction score 17,830 farmo83 said: What all is involved in releasing a prop shaft from a casale drive ? Click to expand... You need to split the coupler. After loosening the row of bolts used to clamp it tight, utilize the opposing bolt holes (2) to spread it. If necessary you can tap the safety collar which should be firmly attached to the shaft.
