REPLACING SPARK PLUGS
MIKE_BOWER
I’m New into Jet Boats is there a trick to slide out the spark Plugs with these manifolds or do I have to take them off Thanks
sintax
you likely just need some small Chinese child hands and maybe a universal joint, doesnt look like its too bad.
bocco
If you can break them loose then use a piece of fuel line over the end of the plug to unscrew it.
TexasJet
If you think getting them out is tough wait till you try to put them back in. It's gonna be a bitch.
Maestro
Thin wall sparkplug socket and an extension should do the trick
78DiMarco
Mine was a PITA too, Banks logs with Big Boostpower Brodix heads that have the plugs in slightly different position. There is a socket available on Amazon I got that is small and slotted that helped. I also tried the hose deal once broken loose and it works, but getting back in is a bitch. I have a fucked up shoulder and it was impossible for me so I had Ron from Bad Attitude do it and he got it done. I gave him a set of the tool mentioned for helping me out, they come as a pair one a little shorter than the other. Good luck
