Bpracing1127
- May 31, 2012
- 10,090
- 13,010
I am going to be adding a second AC and need a few items fixed. Who is the go to shop for these things?
Colton Truck Terminal Garage.
Sport pharmacology as the best aid to build a perfect body Our shop → Steroids for the best price The fast pace of our daily lives consumes a lot of energy and requires an optimization of the time spent in all the processes that occur in it. Many people who have not seen quick results […]coltontruckterminalgarage.com
Everyday of the week and 2x on sunday. This is a great shop
Not sureThey don't add AC's do they? Only chassis work,engine/trans stuff ...No?
Do some research on the 2nd ac my buddy added a high efficiency one his 5er and he just ran a cord with a 20 amp plug Then he plugs into the convince outlet On the post at the camp ground
That’s exactly what I am doing. My trailer is 30 amp so can’t run two anyways. But the second will surely help at havasuthis. I have 2AC‘s already. Adding 3rd and wiring it so it runs off the pedestal and not powered through my trailers electrical system.
Maybe not as close as you'd like but these guys are worth the trip. I brought my toyhauler all the out from Phoenix so Jim could have his guys do the work I needed.
VIP RV Service - Jim Goodwin - Menifee, CA
VIP RV Service in Menifee, CA. provides top quality repairs. Jim Goodwin has extensive knowledge with Weekend Warrior and many other brands.www.viprvservice.net
Had Jim at VIP do the exact that on my toyhauler. Very clean install with an outlet on the outside of the trailer to run a separate cord to the 15amp plug on the pedestal. Highly recommend these guys I have taken mine there since new.That’s exactly what I am doing. My trailer is 30 amp so can’t run two anyways. But the second will surely help at havasu
What are you inside temps when it’s 115 outside? I am seeing 92-93 inside temps when it’s that hotmy trailer is 30amp as well. Run 2 13.5’s currently, but with 9.5’ to the ceiling, 2 is not enough.
Check to see if the new AC location is already pre-wired for AC and Tstat. If so, easy drop in DIY.
No RV roof AC systems can handle temps above 105F very well. Above 110F forget it.
115 is my F it is hot inside limit.
need to find something that shades the roof but can withstand Havasu monsoons
I did, not prewiredCheck to see if the new AC location is already pre-wired for AC and Tstat. If so, easy drop in DIY.
This. we have magne shade on windshield and drivers window. Bought a couple of 48” rolls of the silver bubble type material that we use inside windshield. I bet front seat area dropped 15 degreesI guess some rigs are insulated better than others. With 115-118 temps, my 2 15K btu roof A/C's will keep the coach in the high 70's to low 80's. The key for mine is exterior window shades on the front windows (class A). And when really hot and the front window is sun exposed, a foil window cover on the inside.
These class A shades are bad ass. And can be custom fit to any window in an RV or trailer
Custom Magnetic RV Window Shades | Magne Shade
Magne Shade® window shades for RVs use small but very powerful Rare Earth magnets that are mounted on the inside of the window. Magne Shade motorhome sunshades install easily from the ground without a ladder. Made in the USA, Magne Shade RV window covers provide substantial heat reduction...www.magneshade.com
