squeezer
- Jul 2, 2012
- 5,900
- 2,796
2009 Sanger V215 46MPH @ 4800RPM
2008 5.7 Black Scorpion (PCM555 EFI computer)
Freshwater only
Looking for a few more horsepower and a bit more RPM for the odd barefoot run. Would not mind taking a few pounds off the stern as well.
Currents thoughts are as follows:
Start with exhaust. ($1-3K)
CMI's or a higher quality cast aluminum set.
(Are CMI's going to show much improvement on a 375ish horsepower SBC?)
Then heads. ($1.5K)
Aluminum of some sort.
Edelbrock E Streets, Fast Burn Bowties, AFR, ?????
Finally a re-flash: ($0.5K)
https://whipplesuperchargers.com/index.php?dispatch=categories.view&category_id=177
(It looks like Whipple is the only game in town for the PCM555 based system.)
The above combination at $4500 should be good for close to 375HP and remove just about 200 lbs off the stern.
Do any of you guys have a specific combination that can be recommended?
Freshwater only
Then heads. ($1.5K)
