Shrub Lurker
- Oct 5, 2018
- 962
- 837
Thanks!
Totalboat product is good, epoxy will be a little more flexible than poly but more expensive. You can thin cheap epoxy down with acetone, be sure to cover all exposed surfaces if you choose that route. Thinned urethane will work just as good if it isn't exposed to constant moisture often. Is it bolted to the floor or removable? I'd be more worried about moisture under it on the carpet if that's the case. Just take it out when in the garage and let everything air out if possible.
I
It's bolted in. The wood against the carpet IS the issue.
Cool, where can I find this ?
